A4 Shifter Question
I have done a lot of work on the car myself and pulled the console once already for the ipod interface install. How hard is it to get the shifter out to swap the bulb?
Removal Procedure
1. Remove the floor shift control. Refer to Floor Shift Control Replacement in Automatic Transmission - 4L60-E.
2. Remove the floor shift control boot assembly. Refer to Floor Shift Control Boot Replacement in Automatic Transmission - 4L60-E.
3. Remove the lamp socket.
4. Remove the bulb from the lamp socket.
Installation Procedure
1. Install the bulb to the socket.
2. Install the socket to the shift boot assembly.
3. Install the shift boot to the floor shift control. Refer to Floor Shift Control Boot Replacement in Automatic Transmission - 4L60-E.
4. Install the floor shift control to the console. Refer to Floor Shift Control Replacement in Automatic Transmission - 4L60-E.
This web site will get you started -
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
