header gasket
Old Jan 30, 2009 | 08:44 PM
z06801's Avatar
z06801
Default header gasket
Can I replace passenger side header gasket by just taking out bolts and pulling back or do I need to unbolt the coupler.
Old Jan 30, 2009 | 09:26 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Probably depends on what headers you are running.
If stock manifolds, you'd have to unbolt, or at least loosen the flange connecting it to the midpipe to gain enough flexibility to replace the gasket.
With most LT headers, you will probably find enough flexibility in the system to do what you are asking, that is, if nothing is tying it to the other side header up near the engine. (example - the X-pipe immediately after the collectors on ARH system might not allow it to happen without loosening the collector flange).
I know you're trying to save a trip under the car, but the proper way is to assemble the entire system, leaving all connections loose, tighten the headers to the heads first, then work your way back, tightening the rest of the connections under the car.
By prying a fastened header away from the head, then pushing it back, you have little/no "wiggle room" when trying to re-start the bolts into the head, and you stand a good chance of cross-threading them if they want to go in crooked because of slight misalignment
Old Jan 31, 2009 | 12:38 AM
z06801's Avatar
z06801
They are long tube kooks and you nail it, I was trying to save a trip under the car thanks for the tips
Old Jan 31, 2009 | 12:54 AM
OhioC5's Avatar
OhioC5
I know why you asked too. Im getting ready to do my heads and was trying to figure out how to stay out from underneath the car.
Old Jan 31, 2009 | 01:45 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
If you're doing a head swap, trust me, you'll definitely need the headers WAY out of the way (if not out completely).
You'll understand when you find the lower row of head bolts.
To header gasket
