Potential A/C problem
Old Jan 31, 2009 | 02:24 PM
alj357's Avatar
alj357
Default Potential A/C problem
Ok, today we replaced one of the headlight gears. Well upon research I also found out that the fuse for my fog light relay was blown. The way I found out it was using another fuse (I believe it was for the A/C unit) Well in any event all fuses are now working but when I checked my A/C (when I hit the A/C button it blinked 3 to 5 times and went off) didn't work. My question is there anything I can do to get it working again or am I forced to have to take it to the dealership? ***I did a search but couldn't find information*** Any advice would be greatly appreciated.
Also, didn't have any error codes on the DIC.
Old Jan 31, 2009 | 03:05 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Are you sure all the fuses are ok? Check fuse #24 to make sure its not blown. If its ok, then its probably your freon charge. Usually the blinking light is a sign that its low and it won't let the compressor run.
Old Jan 31, 2009 | 04:04 PM
alj357's Avatar
alj357
Hey thanks! Double checked fuse 24 and it's okay. So I guess I will check into getting my A/C recharged.
To Potential A/C problem
