Recently I had some friends insist that the Z06 GM/Getrag 3:42 Diff (from GM Parts) already has hardened output shafts.
I had always thought this was something you would have to upgrade yourself prior to install.
Is this ???
As far as I know the difference was the Z06 had a 3 rib case. Im no expert but, hardened shaft...right.
The only difference that I knew of was that the Z diff had the shot peened case and the base 3:42 diff did not??? But the hardned output shafts? Hmmmm....
