Torque Tube Question
Old Feb 5, 2009 | 11:05 AM
dsipos05's Avatar
dsipos05
Default Torque Tube Question
I just bought a Z06 torque tube and when I first got it, i noticed the tranny side of the TT is different than 2000 MN6 TT. The one I just received has a round plate with 12 or so bolts in it around where the shaft connects to the TT. Is this how the newer z06 style is?? as i thought it looked the same as my '00 TT which does not have any bolts showing. Is there a way to check to see which style the TT is??
I can post pictures when i get home. Thanks!!
Old Feb 5, 2009 | 11:25 AM
WKMCD's Avatar
WKMCD
I don't know that I would install it without inspecting the rubber bushings inside. If it is a Z06 or later C5 TT it will have 12mm bolts through the bushings.
Old Feb 5, 2009 | 11:42 AM
lucky131969's Avatar
lucky131969
Are you sure it's 12 bolts....and not 8?
If it is 8 bolts, you got yourself a pretty rare torque tube....Z06 with an A4....
Old Feb 5, 2009 | 11:54 AM
dsipos05's Avatar
dsipos05
hahah thats what i thought at first but it has the bolt holes for the shifter and it actually came with a slave cylinder, im pretty sure its 12 bolts, but ill be able to post some pics later.
i thought there was some way to tell which style it was whether it be the older 10mm or newer 12mm from a marking somewhere on the outside of the TT...?
so i should open it up to check out the bushings??
Old Feb 5, 2009 | 11:55 AM
Mike Mercury's Avatar
Mike Mercury
starting model year 2001 or 2002 (someone help me here...) all C5's got the Z06 torque tube; even the A4's. Basically the only change is the increased diameter of the rotating shaft.
Old Feb 5, 2009 | 12:10 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
All six speeds have the 12mm couplers from 2001 forward.
I don't think they upgraded the auto's though from what I've heard. I'll no more when I convert back to an auto and inspect the auto's TT.
Old Feb 5, 2009 | 12:13 PM
LoneStarFRC's Avatar
LoneStarFRC
Pretty sure the A4s still didn't use the rubber vibration "donut" on the actual driveshaft like the 6-speeds have.
Question: Is the rear bell housing bolted to the torque tube or factory welded?
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
97-99 M6 with 10mm coupler bolts have the bolt on removable rear bellhousing. Post up a pic and I will confirm.
Old Feb 5, 2009 | 12:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
BTW, the auto's have bushings too.
Welded.
Old Feb 5, 2009 | 02:43 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What I remember reading, that the 2001 Z06 TT inner driveshaft diameter increased in diameter from 55 to 63 mm. Then in 2002 ... all C5's got the larger 63mm inner driveshaft.
According to the GM C5 Parts manual I have all 2001 and up share the same shaft.
GM PART # 88894025
CATEGORY: Propeller Shaft
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $802.14
OUR PRICE: $583.96
Old Feb 5, 2009 | 02:44 PM
Mike Mercury
What I remember reading, that the 2001 Z06 TT inner driveshaft diameter increased from 55 to 63 mm. Then in 2002 ... all C5's got the larger 63mm inner driveshaft.
Old Feb 5, 2009 | 03:49 PM
dsipos05's Avatar
dsipos05
hey ajg1915, in that parts manual on page 3-J18 is the diagram of the torque tube I originally had, and 3-J13 is the torque tube that was sold to me as a z06 TT. So i pretty much got screwed then huh??
i bought from someone on this forum, how do yall think i should go about handling this, when it was sold to me as a Z06 TT? it just sucks too, cuz i havent had my car for over 2 months(which is my DD) and ive been ridng with my wife and now after thinkin i finally found the z06 TT i didnt and im back to square one, actually worse off than before cuz i spent $400 bucks on a downgraded part, which has a broken bolt in the shifter hole too!!
Old Feb 5, 2009 | 03:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Typically there is a part number on the outside of the torque tube assembly which you go by to determine if it's a latter 2001 -2004 model or the earlier 1997 -2000 model.
What's the number on the outside tube assembly ?
Old Feb 5, 2009 | 07:52 PM
WKMCD's Avatar
WKMCD
Post a pic. Rodney will look at it for .00015 seconds and tell you exactly what it is.
Rodney's the man!!!
Old Feb 5, 2009 | 08:12 PM
dsipos05's Avatar
dsipos05
i didnt grab the number while i was over there, but i got some pics
here is the original one out of my 2000 FRC
and here is the one i was sold as a 2002 Z06 TT
Old Feb 5, 2009 | 08:40 PM
2A372C's Avatar
2A372C
I'm pretty sure the one on the top is the same one I have in my Z.
Old Feb 5, 2009 | 08:55 PM
Former Vendor
.00015 seconds later. That is NOT originally from a 2002 Z06. I'm not saying that it wasn't removed from a Z06 because it will fit and might have been installed from a previous owner. That is a 97-99 torque tube. Sorry
To Torque Tube Question
Old Feb 5, 2009 | 09:23 PM
WKMCD's Avatar
WKMCD
What took you so long?
Sorry to the OP.
Old Feb 6, 2009 | 10:47 PM
LoneStarFRC
BTW, the auto's have bushings too..
I was speaking about the rubber "donut" located about halfway between the two rubber couplers. I think it is either bonded or "fused" to the aluminum driveshaft. It is used on the MM6/M12 shafts due to the "whipping" action of the driveshaft when subjected to the more severe (and sudden) shock-loads of a manual trans car. The torque convertors in the M30 drive-line is more forgiving on the driveshaft and doesn't transmit the shockload as suddenly.
Did you find:
GM PART #88894016
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $1,133.93
OUR PRICE: $825.50
I have an older parts CD ROM but the listings are good up to '02 and it shows two different drive shafts. Also in my '99 shop manual the illustration shows two different shafts inside the torque tube.
Old Feb 7, 2009 | 12:11 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Did you find:
GM PART #88894016
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $1,133.93
OUR PRICE: $825.50
about the center rubber donut on the manual tranny torque tubes vs the auto's who don't have one.
Not sure about the shafts you're talking about though.
