How Do You Raise A Lowered Front?
Old Feb 5, 2009 | 02:08 PM
Ron Dittmer's Avatar
Ron Dittmer
Default How Do You Raise A Lowered Front?
I bought a 1999 convertible. The front end sure looks like it was lowered. I would like to bring it back up to the stock position, but have no clue what was done, and how to un-do it.
Any advise?
Old Feb 5, 2009 | 02:11 PM
slothy's Avatar
slothy
screw the adjuster bolt down - look for a how-to on lowering and do the reverse - is the back lowered too?
Old Feb 5, 2009 | 02:38 PM
Ron Dittmer
The back appears to be normal.
Thanks for the tip. It sounds pretty straight forward. I hope it truly is.
Does the adjustment effect the wheel alignment?
Old Feb 5, 2009 | 02:42 PM
slothy's Avatar
slothy
yes, but if you raise it up drive a few days to let it "settle" before alignment. i guess depending how low it really is, might not have too. only a few bucks to get a alignment anyway worst case.
Old Feb 5, 2009 | 05:14 PM
Ron Dittmer
Thanks slothy!
Old Feb 5, 2009 | 05:38 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Any advise?
My question would be............ why??
Old Feb 22, 2009 | 12:56 AM
Ron Dittmer
n/a
Old Feb 22, 2009 | 01:08 AM
slothy's Avatar
slothy
take a picture of the car sitting a flat surface, hard to see in pic but is the rubber part that at the bottom of that bolt (sits on lower control arm) cut? looks alot smaller dia then stock from what im trying to remember.
that should have made the front more then enough higher then stock
Old Feb 22, 2009 | 01:40 AM
Ron Dittmer
n/a
Old Feb 22, 2009 | 01:48 AM
slothy's Avatar
slothy
gonna run out to take a pic of mine, since i have the front end apart. mines cut but might show something you might noticed diff.
how much fender to tire gap did u have? with tire on
Old Feb 22, 2009 | 02:02 AM
slothy's Avatar
slothy
well i guess this picture is kinda useless, but anyway as u can see its lower all the way + the bushing is almost cut off, i left "1" layer.
and with that this is how it sits
Old Feb 22, 2009 | 08:51 AM
Ron Dittmer
n/a
Old Feb 22, 2009 | 09:41 AM
FRCTony's Avatar
FRCTony
Ron,
From your pic, it does not look to have been lowered at all, and the bushing looks to be intact. There is no "standard" distance, the screws are just adjusted to obtain the correct measurement at a couple of points on the frame and control arms to ground.
It is possible you have a bad spring. Have you looked at the spring for signs of damage?
Do you have any pictures of your car? Where are you getting scraping? Have you had the alignment checked?
Old Feb 22, 2009 | 10:13 AM
Chevy-SS's Avatar
Chevy-SS
....[/IMG]
Damn, that's about as low as you can go. I'm surprised your car is drivable. You must live in an area where the roads are in good condition.
I live in Rhode Island, where the roads are HORRIBLE. If I ever lowered my car like that, it would quickly be ruined, lol.....
Old Feb 22, 2009 | 11:29 AM
slothy's Avatar
slothy
nope roads are horrible here, but its not bad, i just trimed 1" off front air damn and all good.
Old Feb 22, 2009 | 01:43 PM
Bill Dearborn's Avatar
Bill Dearborn
First thing you need to do is find out whether or not you have a problem. The way to do that is to measure the trim height of the car. Here are the measurements for the trim height (you can measure J and K without special tools):
The following picture shows where to make those measurements:
Those locations are ~ where the frame shipping slots are located. Make sure the car is on a level surface when making the measurements and measure from the ground to the frame. Do not measure from the ground to the body work as GM does not specify that dimension and it can be different from side to side and from car to car.
Bill
Old Feb 22, 2009 | 01:56 PM
Ron Dittmer
Bill,
This data is exactly what I need to know, how far I am from the stock height.
Thank You so much!
Boy I wish I had a service manual.
To How Do You Raise A Lowered Front?
Old Feb 22, 2009 | 02:00 PM
slothy's Avatar
slothy
look in general there is the dvd version you can download
Old Feb 22, 2009 | 02:06 PM
Ron Dittmer
n/a
Old Feb 22, 2009 | 02:09 PM
slothy's Avatar
slothy
ouchy on tires!
