Installing headers x-pipe, is this a do-it-yourself job.
Old Feb 7, 2009 | 09:24 PM
Nate B's Avatar
Nate B
Just installed my tpis headers and x-pipe today, took about 4 hrs. The hardest part for me was relocating the 02 sensor wires so they didnt contact the headers. I would say do it yourself and save some money.
Old Feb 7, 2009 | 09:31 PM
itzza427's Avatar
itzza427
Originally Posted by Bill Curlee
If they dont come with new fasteners, you can use the OEM ones. They will work just fine. Ive used mine 3-4 times and there still fine.
You may have to pay attention to the bolt length,,If your stockers are cast iron,might need a washer or two!!
Old Feb 7, 2009 | 11:10 PM
Fast Cop's Avatar
Fast Cop
Do you use any hi-temp anti-lock for any of the bolts? (ie on manifold bolts and 02 sensors)
Old Feb 7, 2009 | 11:27 PM
bumble-z's Avatar
bumble-z
I would use anti sieze on the header bolts, air tube bolts, and spark plug threads.
Old Feb 7, 2009 | 11:54 PM
sami85L98's Avatar
sami85L98
U can use Anti sieze, but i did use oil on bolts instead of anti sieze, 3k miles sofar no exhaust leaks. U might have to use washer's or might gring stock exhaust bolts for not bottoming out in heads, may eb u dont have to either, but in my case SW LT headers flange thickness is not really thick as stock flange, so i grind stock bolts ust a hairline not much, dont wanna torque too much in Al heads. GL on install its fun ride.
Old Feb 8, 2009 | 09:05 AM
B-Vette's Avatar
B-Vette
Originally Posted by nj02vette
Difficulty to install depends on many things. Do you have jackstands? Can you get (or feel comfortable) getting the car 20" off the ground?
What about tools? Have a good selection.
I hate to break it to you, but Kooks are the hardest (that I've heard) to install.
ARH's are unquestionably the easiest. The LG Pro's aren't that bad either.
However, with the Kooks, I'm pretty sure you have to unbolt one of the motor mounts and jack up the engine to get clearance. Even with that, it should still only take a day.
My advice, buy a new set of spark plug wires (GMPP recommended). You'll probably break one trying to get it off.
You do have to unbolt the motor mounts to do the install as per Kooks instructions.
Old Feb 9, 2009 | 10:15 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
I wont do 200 but i might be able to come close to that. PM me if you are interested.
Old Feb 9, 2009 | 10:29 PM
99FRC Newb's Avatar
99FRC Newb
+1 had to jack the engine to install my 1 7/8's kooks headers
Old Feb 9, 2009 | 10:34 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
why does this picture look like a stupid move to me?
Old Feb 9, 2009 | 10:38 PM
Fast Cop's Avatar
Fast Cop
Old Feb 9, 2009 | 11:09 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is another How to on installing Headers!
You will not have a problem if you have some wrenching Skilllllz
http://www.ls1howto.com/index.php?article=29
Thanks,Matt
