Transmission problems
Old Feb 9, 2009 | 12:17 PM
Philip@HPE's Avatar
0Philip@HPE
Former Vendor
Default Transmission problems
The transmission started acting up on me about 3 weeks ago, so i had it pulled and got all new synchros and bearings with a steel shift fork.. got the transmission on the car, drove it around a lot... and after i felt that i had broken it in nicely, the first resemblance of aggressive driving i did, 3rd and 4th gear began to grind.. So I have talked to a some shops and people i know and i have come up with a few possible reasons for why it is acting up.
A. the tranny is taking a dump on me again
B. the clutch lines need to be bleed
C. The short throw shifter is the problem
D. i need a new master and slave cylinder even though those were just replaced 3 weeks ago
Also i found it quite interesting that when driving around, if i double clutch before going into 3rd or 4th, it doesnt grind
