I know this is a dumb question but how do U get the rear license plate surrond off without breaking it?
You should only have to take the two top screws out and the bottom will be in two clips attatched to the Plastic License Plate frame!
When you remove the plate the frame should come off with it! You might have some screw covers over the screws so you will need to take those off first to access the screws
Thanks,Matt
I have taken the 4 screws out but it still won't come off. It's cold hear in Mich and I don't want to brake it.
From: Huntington Beach / Fountain Valley California
Never Mind - I figured out how to get the Blasck Plastic Frame off - HOWEVER - It appears that you can not use a Generic Chrome License Plate Frame as the black plastic surround covers a lot of the mounting surface behind the license plate and a standard Chrome License Plate Frame shows the background around the chrome frame without the Original Black Frame being there.
Is there a Chrome License Plate Frame available for the C5 without having to spend $150 for a fancy billet frame that goes around the back-up lights ???
Or am I supposed to keep the black plastic frame there and put a Generic Chrome frame OVER the black plastic frame ? (this will look rediculous if I do that)
Any tips on a good Chrome frame that actually fills the gaps (wide edges) reasonably priced ?
Look closely at both vertical sides. On the inside (center of car side) you'll see 4 slots. Push a small screwdriver in the slots to push the locking tabs outward. CAUTION, be very careful, they break easily, COLD weather won't be in your favor. Do 1 corner at a time, and push the minimum amount to unlatch it. Carefully!!!!!!!!
Edit: Looks like I said all that too late, sorry bout that.
Thank You - I figured out how to get the Black Plastic Frame off - But replacing it with a Generic Chrome Frame does not seem to fit properly - You see the background of the mounting surface around a Generic Chrome Frame - I dont really want to spend $150 for a Custom Billet Frame - What CHROME Frame will fit properly without using the Black Plastic Frame ?
Originally Posted by jrose7004
Paint it body color while you have it off. Looks real cool when you do that.
Hmmmm - Now Thats an idea - But where do you get Torch Red Spray Paint ? Do you have to put a clear coat over it ? Might end up costing mre than a new frame ?
