Why does this car give me so many problems??
Old Feb 9, 2009 | 05:49 PM
Ayankees2772's Avatar
Ayankees2772
Default Why does this car give me so many problems??
The dealership just called me back and told me they are going to charge me 700+ to install a new column actuator as well as a relay in my car. Recall variation 04006 was done in 04. Is the actuator easy to replace? Should this be covered if I keep on customer service? Please give me some advice. I get the pull key and wait 10 sec as well as the service column lock. I've tried to column lock bypass but that will only prevent a probem not fix it. I've tried removing the fuses, disconnecting the battery, jumping 87 to 30 pin, all with no luck. I have a 03 6speed. The only thing performed in 04 was a reprogram of the ecm.
Help
Old Feb 9, 2009 | 06:32 PM
Ayankees2772
Does the actuator need to be working for my clb to work correctly?
Old Feb 10, 2009 | 02:21 AM
chriskaw7r's Avatar
chriskaw7r
Help
Why not by pass it? I would tell them to shove that $700. Just a FYI for yah dealers will be looking to there service departments for $$$$ as new car sales have dried up! I have had mine by passed and see no need for it!
Old Feb 10, 2009 | 02:23 AM
chriskaw7r's Avatar
chriskaw7r
As long as you can turn the wheel it should be retracted and install the by-pass. If it still is not working double check the instructions!
Old Feb 10, 2009 | 06:08 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
The dealership
There's your problem.
Old Feb 10, 2009 | 07:37 AM
tomurphjr's Avatar
tomurphjr
Help
Correct me if I'm wrong, but I thought the 97-2000 auto car were the only car to have the column lock issue?
Old Feb 10, 2009 | 09:38 AM
jovette's Avatar
jovette
You are wrong.
Old Feb 10, 2009 | 10:24 AM
tomurphjr's Avatar
tomurphjr
Originally Posted by jovette
You are wrong.
Yes, it appears I am wrong and right. Thanks for your post...very helpful!
This is what I found
1997-2000 A4's are affected. 2001 or newer, the ECL lock plate was replaced.
1997-2004 MN6 and MN12 are affected.
Old Feb 10, 2009 | 10:29 AM
'02magredZ51's Avatar
'02magredZ51
You are wrong.
All have or will develop the problem.
For those of you that are going to reply, "I have 1,000,000 miles and no issues with mine." You're next.
Do the by-pass. You'll be glad you did.
(And my '02 MN6 did it less than 6 months out of the factory).
Old Feb 10, 2009 | 11:02 AM
itzza427's Avatar
itzza427
Originally Posted by 8VETTE7
For the 2001 and newer GM did MUCH more than just replace the ECL lock plate. If that was all they did then having recall version 04006C done to the MN6 M12 cars would cure all the Column Lock problems out there and it doesn't. There are plenty of cars with that recall that still experience the Pull Key and wait 10 seconds and/or Service Column Lock error messages. True the column does't lock any more but they can experience the fuel shutoff.........
Amen brother,,, Mine had 2 recalls done over a period of years,including the infamous "computer reprogram"!!The steering wheel could be turned with the key put. After about 7 months of occasional random PULL KEY WAIT 10 SECONDS,, She bit me with the 10 second followed by service column lock with the now programed 2mph fuel cut off. Had to have it towed home where I installed the CLB I had purchased and just hadn't gotten around to.Been motoring carefree ever since. DO THE CLB YOURSELF and politely tell them to shove their $700 repair (that STILL won't cure the problem), where the sun don't shine!!!
Old Feb 10, 2009 | 11:11 AM
redrckt97's Avatar
redrckt97
I had mine done at the dealership last June - WAY past the 2004 "cutoff" at zero cost to me. I surely
should have done the CLB before the problem though!
GM should be paying the dealer for this so its still a money-maker for the dealer - may need to
talk to the service manager. If the 4006 had already been done once on your car, they likely will Not pay for it again.
Old Feb 10, 2009 | 11:37 AM
99silvercoupe's Avatar
99silvercoupe
just by pass the fuel cut off, you will get an intermintent pull key wait ten sec...but if you do , car starts right up, and if you are really ****, you can clear the codes int he dic.
Old Feb 10, 2009 | 11:48 AM
TEXHAWK0's Avatar
TEXHAWK0
No..Do not let the the dealer tell you that you need a working actuator to get the column lock system working.
The aftermarket column lock bypass relays leave the actuator disconnected, and even the GM Harness K will work with the actuator disconnected. GM leaves it in the circuit most likely to provide the correct resistance to circuits in the BCM, but the system should still work without it.
I would press to have the dealer replace the defective GM Harness K relay and leave the actuator disconnected. I assume you have had the lockplate removed as part of a recall, so that the column cannot physically lock. If not, then the dealer did not complete the last recall.
Old Feb 10, 2009 | 02:39 PM
MACKASH's Avatar
MACKASH
Sounds like the typical stealership.
Old Feb 10, 2009 | 10:04 PM
Choreo's Avatar
Choreo
For the 2001 and newer A4's GM did MUCH more than just replace the ECL lock plate. If that was all they did then having recall version 04006C done to the MN6 M12 cars would cure all the Column Lock problems out there and it doesn't. There are plenty of cars with that recall that still experience the Pull Key and wait 10 seconds and/or Service Column Lock error messages. True the column does't lock any more but they can experience the fuel shutoff.........
So are you saying that if I have a 2001 A4, I still need to do something?
Old Feb 10, 2009 | 11:28 PM
nuck's Avatar
nuck
Help
Are you getting fuel cut or just the message?
Old Feb 11, 2009 | 01:46 AM
Ayankees2772
I am getting the fuel cut off. I had recall version 04006 (first variation). It was done in 2004 prior to the nhspa required the other variations of the recall. Does recall 04006 do anything else other then reprogram the ecl? Because that's all that were on my notes when i called chevy asking about my recall. Thanks for all the help. I'm going to sign up as a member asap.
To Why does this car give me so many problems??
Old Feb 11, 2009 | 02:12 AM
Ayankees2772
The relay with the yellow line in pic 1 is the same as the one im holding...that is where i found the wires i thought i had to jump. 87 to 30.
Old Feb 11, 2009 | 03:35 AM
richard emmanuel's Avatar
richard emmanuel
Default sterring lock
I had the same problem so I took my 02-6speed in to a dealer and they fixed it for free. 9 months later problem re occuried while out of town and now i was in a jam. I wiggled steering wheel forcefully back and forth praying air bag would not deploy and to my surprise sterring unlocked it self after about 10-15 seconds of this . Eveery 2-3 weeks problem kept reoccuring and i solved it each time using this jiggling motion. I took it to a different dealer ship and explained to them the problem and i intenionaally did not tell them what other dealer had done. They fixed problem and 6 years later not one incident of that steering column wait 10 second pull key drama.
Old Feb 11, 2009 | 03:43 AM
Ayankees2772
I dont have the k harness installed, and sometimes the column will lock when i pull the key out. I've never had one problem with the column not unlocked once I put the key back in. Am I missing something when i say i dont have anything behind my bcm? Its the silver piece in my picture correct? You can see behind the bcm and there isnt one cable.
And I called the customer service number for gm and she pulled up my service and said the variation was 04006. Im assuming that means its the first variation correct? Or do I have to go to the dealership? I thought they would both have the same info.
