The driver seat on my Corvette should get new seat base foam when I install new leather skins. I was wondering if anyone had success in bringing the old foam back to it's original fluff, or has added something like foam carpet padding to fill in the extra space.
Other than buying from GM, is there a source for new foam? What can I expect to pay for a new seat base foam from GM or other source?
Just had a local upholstry shop renew the side bolsters and the seat foam on the base. They found that the springs had spread and allowed the foam to compress into the open spaces. Their fix was to realign the springs and wrap with protective spring fabric to eliminate future problems. To my knowledge, they used automobile seat foam to rebuild the base and bolsters. Seems likely you could purchase some of this foam from any local auto upholstry shop. Total job cost $100 so the foam should be very modest in cost. Good luck...
A1
I used a steamer and ran it all over the foam it softened and swelled substantially, the color even got lighter. To me it appeared that it returned to original shape as my new seat skins fit very tight.
I lined the seat bottom wires with a hunk of carpet and lined all exposed frame edges on the bottom and back with Vinyl tubing. I used spray adhesive to glue together all the rips and cuts from the wires and frame...
