Bleeding the brakes?
Old Feb 11, 2009 | 09:53 PM
DBLX's Avatar
DBLX
Default Bleeding the brakes?
How should I bleed the brakes? Car running or off? Farthest to closest wheel. Just pump up the brakes, hold, release fluid/air, close valve, repeat until fluid only, no air?
Old Feb 11, 2009 | 10:15 PM
ericdwong's Avatar
ericdwong
Bleed with car off. Correct, furthest wheel from master cylinder then move closer. Yup, pretty much, helps to have a 2nd person!
Old Feb 11, 2009 | 11:31 PM
Oldvetter's Avatar
Oldvetter
There are many ways to bleed brakes: manual/2 person, vacuum, pressure, gravity.
There are 2 different sequences, depends on year (location of abs pump, early years have it in back, later years in front).
Don't leave the master cylinder go dry or you will need a TECH II to bleed the abs.
Old Feb 11, 2009 | 11:38 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I installed the speed bleeders when I had my calipers powder coated. One person job now. Put a hose on the end and loosen the bleeder and pumped till the fluid came out clean. Tighten and then moved to the next one. Just make sure you check the level of the reservoir so it doesn't get empty on you and the cap is tight when you pump them.
Old Feb 12, 2009 | 01:20 AM
ljthe2nd's Avatar
ljthe2nd
I have used speed bleeders but the easiest way to bleed your brakes is with a Motive Power Bleeder. http://www.racerpartswholesale.com/c...Brake_Bleeders
I have one of these and its so easy to use, just take the cap off of your master cylinder and attach the Motive Power Bleeder. Fill it up, pump it up to 15 psi. Go to each wheel put a hose on the bleeder and put the hose into a jar and open the bleeder until air bubbles quit. Check the pressure in the power bleeder before you go to another wheel and pump it back up. Thats all there is to it. You can bleed your brakes in about 10 minutes.
Old Feb 12, 2009 | 06:45 AM
DBLX's Avatar
DBLX
Okay, I don't have a power bleeder but... What's the Tech II? So there's nothing special to do concerning the abs unit?
Old Feb 12, 2009 | 11:33 AM
Last C5's Avatar
Last C5
The correct bleed sequence for C5s depends on the year.....
1997 to 2000 RR LR RF LF
2001 to 2004 RR LF LR RF
Old Feb 12, 2009 | 12:11 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
A tech2 is a handheld device used to diagnose and program the PCM, BCM and electrical system of your car.
Old Feb 12, 2009 | 12:58 PM
TEXHAWK0's Avatar
TEXHAWK0
I would suggest you just manually bleed the brakes in the order noted above.
No need to pump the brakes. Just have a helper push the pedal down and hold the pressure constant, crack open the bleeder valve, close it when flow slows, then tell the helper to slowly let the pedal return to normal height. Do this until you get clean fluid and no air bubbles.
I use a clear plastic hose from the bleeder to a small bottle (I used a coke bottle)
The Tech II can be used to open the circuits in the ABS system to get new fluid in to all the circuits, but these circuits are normally closed, and it is possible to manually bleed the brakes without getting air into the ABS contol block. Just make sure you keep the reservoir full. I have actually replaced the master cylinder, then bled the air out the M/C ports, and would not have had to bleed the system at all. I went ahead and bled each caliper because I wanted to get clean fluid into the system.
Old Feb 12, 2009 | 04:59 PM
DBLX's Avatar
DBLX
What if i have air in the ABS block? Will bleeding the normal way work?
Old Feb 12, 2009 | 05:06 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If you have air in ABS module, after first bleed take the car out and stomp on the brakes hard to set off ABS.
COme back and re-bleed brakes.
Old Feb 12, 2009 | 08:25 PM
DBLX's Avatar
DBLX
Will do!
Old Feb 13, 2009 | 08:07 AM
jimish's Avatar
jimish
Can you make a Motive Power Bleeder by installing a tire valve in a spare master cylender cover? How does the gasket work? as a diaphram?
To Bleeding the brakes?
