I am headed to the Yellowstone area this weekend from So-Cal for a 2 week vacation.
I need advice from C5 owners that drive their cars in the snow. Is there anyone that actually does that
Is there any type of traction device that will fit on a stock C5, chains, cables, etc. ???
Any advice besides "Don't go" would be appreciated.
Bill
I'd try some nice snow tires and start off in 2nd gear. I would not use chains, etc... because if they break you'll take out a fender and probably the rear tub which would cost a fortune to repair, even if you could do the work yourself.
Use good winter tires and add some weight to the back.
Instead of chains I would prefer cables since they aren't as bulgy and also offer good traction.
If you intend to drive in deep snow, raise your vehicle at the spings ends to gain more ground clearance.
Remove your front air dam underneath the radiator to not act as a plow.
Alex
Since I may not see snow on the road, I was just looking for something temporary in case I run into a road situation where they won't let you continue without chains etc.
If I was going to spend an extended time in snow country, snow tires would certainly be the answer.
Studded tires would be the best, but I am sure you could find some chains or cables that would fit. When using chains or cables make sure you test fit them before use and cut off any excess links; especially the inside of the chains. After driving a 50 feet or so it is a good idea to re-tighten the chains/bungee cords and drive slow 25 MPH. good luck
I doubt that you will be in an area that requires mandatory chain up, if so it may be tough to drive a vette even with chains.
Thanks,
Bill
Dude, your going to Yellowstone not Disney land. They don't start plowing the roads in the park for another 2 weeks. And then it will not be fully open until the 15th of March. Even though its a farily mild winter snow tires are required in what roads are open: http://www.nps.gov/yell/planyourvisi...eport_0212.pdf
The interstates may be passable if you go slow enough, but that is a definite gamble. We are getting snow tomorrow and Sunday, there are several fronts moving through the region, so you WILL see snow. Off the interstate I would be tentative with my SUV this time of year. Here is what Teton pass looks like right now: http://www.wyoroad.info/highway/webc...onPassAll.html
The weather forecasters in this region are more reporters than forecasters. I would not suggest betting on them.
Bill
OK, "go, but not in the corvette............how's that for advice you asked for? I agree with MattB.........you are really asking for trouble, going to yellowstone in a corvette, this time of year.
Thanks, I wasn't planning on going into Yellowstone, but staying in West Yellowstone and taking a day trip into the park on a Snowmobile or Snowcoach. I have been there before and am only going for some snow covered geyser photography. I will actually be staying near Butte.
Chains will work. I have seen 2 or 3 porches keep them in the trunk. If terrible weather hits they throw them on. Soon as the road starts to thaw take em off. Better safe than sorry. Just remember to keep it slow with chains on the vette they are only there to get you through some bad weather if necessary.
I used stock tire size on Dunlop M3 17" and "Z" cable style chain. One winter I passed highway patrol with just the M3's and no extra weight. Crown Vic Trooper wasn't happy and pulled me over. Got home to about 10" and didn't want to leave the car anywhere so I brought the Z cables. I was plowing the stuff to get down my street! Never had them much over 20 mph as they do ride rough but did the job. Probably cost $150 for the pair. Just google or check the infamous auction site. PM me for a pic!
I'd still be wary, I-80 can be a b!$* in a snow storm. Snow tires would still be a good idea. I've driven in a snow storm in the Vette and it is dicey at best. Got caught in a snow storm coming home from a HPDE. There were SUV’s in the ditch every mile, it was not fun but I did make it. The torque made it almost impossible to use the accelerator and the traction control is almost useless on bad ice because it allows a little wheel spin and by the time it engages your almost sideways. Go slow would be my advice... and avoid the snow as much as possible.
But, the purpose of your trip sounds cool, I'm inot photoraphy as well. I need to visit Yellowstone in the winter, I'm sure there are two weeks worth of subject there in the winter.
