LS6 intake question???
Old Jan 24, 2002 | 05:55 AM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Default LS6 intake question???
Do all 2001 and newer C5s have the same intake manifold as the Z06's.I guess my question is can you tell a LS6 intake by having the brass inserts on the passengers side and NO EGR hole.If there is a difference does anyone happen to have both part #'s. :confused: :confused:
Old Jan 24, 2002 | 06:17 AM
C5Cemo's Avatar
C5Cemo
Default Re: LS6 intake question??? (Crashed 94)
Yes, all 2001+ C5's have the same intake manifold.
The brass threaded inserts are installed in the manifolds for the general market, more specifically 01+ prod. F-bodies and for aftermarket demand for a similar application...to attach their standard throttle cable assy. to. All of the OEM C5/Z06 manifolds I have seen do not have these.
The EGR hole is for an F-body as well but only for pre-01's that want an upgrade to my knowledge. The EGR system is no longer used on any LS1 since the redesign.
Here is the P/N for the '01+ manifold: #88890523
Old Jan 24, 2002 | 12:42 PM
George Cooper's Avatar
George Cooper
Default Re: LS6 intake question??? (Buckmaster)
There was some stuff here a while ago suggesting that the LS6 intake was less prone to water ingestion. Has this held up?
Old Jan 24, 2002 | 01:08 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: LS6 intake question??? (C5Cemo)
'97-'00 = #12557846
'01-'02 = #88890523.......The new LS6 (redesigned) Intake Manifold P/N #88894339.
[Modified by 97C5ENVY, 11:22 AM 1/24/2002]
To LS6 intake question???
