C6 Z06 Sway Bars Help
Old Feb 15, 2009 | 12:41 PM
hp400's Avatar
hp400
Default C6 Z06 Sway Bars Help
HI every body just want to clarify do C6 Z06 sway bars fit on a c5 .I have been told that they do and do not fit. Please respond I need to pull the trigger by tomorrow.
Old Feb 15, 2009 | 02:03 PM
MagRedConv's Avatar
MagRedConv
Your probably confusing the springs with the sways. Springs - no, sways - yes.
Old Feb 15, 2009 | 02:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
yes, they fit. i run them.
Old Feb 15, 2009 | 03:45 PM
AQWIKZ's Avatar
AQWIKZ
pull the trigger the C6 Z06 sway bars do fit without any problems.Iam running them on my Z they work great.
Old Feb 15, 2009 | 03:47 PM
hp400's Avatar
hp400
Thanks guys appreciate it alot.
Old Feb 16, 2009 | 01:14 PM
vettegator005's Avatar
vettegator005
are the c6 z06 sways better than the c6 z51 sways?
Old Feb 17, 2009 | 03:06 PM
vettegator005
Old Feb 17, 2009 | 05:52 PM
The Wrench's Avatar
The Wrench
That's a Big Momma rear bar. It looks so good it must add at least 5 Hp and 1/10 G. I want some! And maybe powder coat the rear one bright red or blue or something.
Ah, mod fever again.
DG
Old Feb 17, 2009 | 07:28 PM
Redhawg's Avatar
Redhawg
DG
Old Feb 17, 2009 | 10:34 PM
lionelhutz's Avatar
lionelhutz
Not unless you have tubs and 335 or so rears on your car. If not, the C6Z06 bar set tends to be have a little too much rear bar which can make the rear end step out on you (over steer or loose are the typical racing terms). The C6Z51 are cheaper and will perform very well for you.
Peter
Old Feb 17, 2009 | 10:41 PM
YeloFevr's Avatar
YeloFevr
Would powdercoating a sway bar weaken it? I'm not VERY familiar with the powdercoating process, but I know enough to know that it goes through a high-heat cycle. And I know what heat can do to metal sometimes...
Old Feb 17, 2009 | 11:44 PM
jdmvette's Avatar
jdmvette
Night Owl for life
flares & 345s here.
Old Feb 18, 2009 | 08:35 AM
99 vett babycar's Avatar
99 vett babycar
Not unless you have tubs and 335 or so rears on your car. If not, the C6Z06 bar set tends to be have a little TOO MUCH rear bar which can make the rear end step out on you (over steer or loose are the typical racing terms). The C6Z51 are cheaper and will perform very well for you.
Peter
I think that may be the first time I've ever seen the words "too much" on this forum.
Old Feb 18, 2009 | 09:57 AM
The Wrench's Avatar
The Wrench
Wretched excess is barely adequate.
DG
Old Feb 18, 2009 | 12:32 PM
vettegator005
between the c6z51 sways and the c5 z06 sways which will work better on my head and cam 99 coupe
Old Feb 18, 2009 | 01:04 PM
dankhts's Avatar
dankhts
Powder coating does not weaken metal.....it's basically just powdered paint electrically charged/adhered to the metal then oven baked to dry...
Old Feb 18, 2009 | 04:02 PM
YeloFevr's Avatar
YeloFevr
Okay...that's what I wasn't sure about (the baking process). Thanks!
To C6 Z06 Sway Bars Help
Old Feb 20, 2009 | 12:01 AM
lionelhutz's Avatar
lionelhutz
Originally Posted by jdmvette
flares & 345s here.
That's why the C6Z06 bars are perfect for you.
For everyone else without those huge rears the C6Z51 bars are the better choice.
Peter
Old Feb 20, 2009 | 12:12 AM
jedblanks's Avatar
jedblanks
Pretty sure the C6Z51 rear sway is larger in diameter than C6 Z06.
Old Feb 20, 2009 | 12:27 AM
lionelhutz's Avatar
lionelhutz
I'm 100% sure it is not.
Peter
