Windshield Washer fluid
Old Feb 15, 2009 | 05:24 PM
mjparrie's Avatar
mjparrie
Default Windshield Washer fluid
I have to say I have other cars and a member of other forums but this one is definately the best. Some of the answers I have read so far are really good. Almost like a manual. I hope this will be the case on mine.
I have a 98 hatch and tried the washer fluid. no noise no fluid. It is full but nothing comes out. Wipers do work though.
Any help would be greatly appreciated.
Michael
98 Hatch "special to me"
Old Feb 15, 2009 | 08:22 PM
byronhunter's Avatar
byronhunter
This is for troubleshooting. HTH
BH
Old Feb 15, 2009 | 08:50 PM
mjparrie's Avatar
mjparrie
I apologize but I need an explination. Is it possible that a fuse may be out to just the washer fluid part?
Old Feb 15, 2009 | 09:48 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Looking at that drawing, if a fuse were bad, you would not have wipers either. When you hit the washer button, do the wipers come on also?
Old Feb 15, 2009 | 10:26 PM
ragtopC5's Avatar
ragtopC5
Do the wipers move when you hit the washer button or nothing at all. If nothing at all it's probably the switch. You don't have to take the steering column apart to fix the switch, I learned this the hard way. All you have to do is pry the little cover off the end and the switch contacts are right there for you to clean.
If the wipers do move when you hit the washer button the motor may be bad. It's on the bottom of the reservoir. You'll have to drain it to take it out and get to the motor. I got a spare motor from a buick at a junk yard. It's a very common gm part, no need to get a pricey corvette one.
Old Feb 16, 2009 | 06:24 AM
mjparrie's Avatar
mjparrie
Thank you all, Yes the wipers do move when I hit the washer button. I will double check that I don't hear anything from the washer motor and just replace it. I appreciate all the replies. I will definately try to find one from another gm. My Mechanic is all about Corvette OEM parts, which is fine, but this is my driver. If I can save a little here and there, I can spend more on the repairs that have to be OEM.
Old Feb 16, 2009 | 05:13 PM
00Corvette's Avatar
00Corvette
Sweet, I have the same exact problem. Please let me know if the new motor cures your problem. I'll try and pop that little button off and see if I can get to the contacts, clean em' and fix it.
Should I just wipe em' off with a tissue?
Thanks so much!
Donnie
Old Feb 16, 2009 | 06:39 PM
lucky131969's Avatar
lucky131969
Do yourself a favor and use a DMM to verify power and ground before purchasing a new pump.
Old Feb 16, 2009 | 06:47 PM
mjparrie's Avatar
mjparrie
I can handle the power and ground. lol. Actually I just got back from the Mechanic (he was doing another repair-New Door panel), he said he tested the motor and it was bad. How much should the motor cost?
Old Feb 17, 2009 | 11:00 AM
87SAM's Avatar
87SAM
Motor should cost about 5 bucks . In actuality, they range in price from 15 to 60 dollars. Napa auto parts may be the easiest choice.
Old Feb 17, 2009 | 07:20 PM
mjparrie's Avatar
mjparrie
Thank you, that is alot cheaper than the 120 my mechanic wants.
To Windshield Washer fluid
