Hit a curb: NEED HELP
Old Feb 15, 2009 | 07:22 PM
derekguzz's Avatar
derekguzz
Default Hit a curb: NEED HELP
'99 vert, selective ride, auto.
Brushed up against a curb with the right side and now my headlights wont go down, car is saying service traction control system and I am getting violent shaking over 60 mph. No body damage and NO prior problems. Please help, Thanks guys!
Old Feb 15, 2009 | 07:30 PM
3XLSX's Avatar
3XLSX
You probably have bent your rim, or thrown off the balance...Which will cause the vibration...
How hard a hit are we talking? You may have broken the spindle...Is the wheel you hit still attached?
Old Feb 15, 2009 | 07:33 PM
AMRAAM's Avatar
AMRAAM
Did you do any damage to the fender? There are some modules right behind it that may have tgotten damaged, but I think the body control module is actually in the pass side floor board.
Old Feb 15, 2009 | 08:21 PM
derekguzz's Avatar
derekguzz
no body damage by the pass side is where it was hit. The wheel is still attached. My dad was actually driving it. He was getting onto the highway. So id say between 30-50mpg. Ill check the light module. It under warranty so ill take it in. Thanks for the advice. But why would the traction control system need fixing?
Old Feb 15, 2009 | 08:50 PM
lucky131969's Avatar
lucky131969
codes please....
dougbfresh's Avatar
dougbfresh
Did you remove the whell and LOOK for damage?
Old Feb 15, 2009 | 09:15 PM
derekguzz's Avatar
derekguzz
no codes checked as of right now im away from my house. and no i havent looked for damage with wheel off. im going to have the alignment checked tomorrow morning. then ill shoot home and check for codes.
Old Feb 15, 2009 | 10:28 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Could have damaged a wheel bearing or ABS sensor in that wheel. Hopefully you didn't bend anything.
Old Feb 15, 2009 | 10:39 PM
derekguzz's Avatar
derekguzz
traction control being in the back that would be the place to look right?
damn my dad messed up this time...who would of thought
Old Feb 16, 2009 | 01:12 AM
lucky131969
Check codes....isolate the problem...fix as required...
Old Feb 16, 2009 | 09:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Remember too that the PCM is sitting right behind the right front wheel.
Old Feb 16, 2009 | 10:34 AM
2GOFAST's Avatar
2GOFAST
There are also sensors associated with the front wheels. Which wheel hit front or back?
Old Feb 16, 2009 | 11:22 AM
derekguzz's Avatar
derekguzz
both front and back...
To Hit a curb: NEED HELP
