Help!!!!!!! 3.42
Old Jan 24, 2002 | 07:55 PM
Jerryk's Avatar
Jerryk
Default Help!!!!!!! 3.42
I want to go to 3.42 gears in my 98 C-5 A-4 with 2.73. I wont be going to the track just alot of light to light and around town, work, daily driving.. Now some say get a TC with it and some say dont ..HELP! what should i do.. what stall speed is the stock TC?? Well I be happy with just the 3.42's?? I have completed the intake and have corsa exhaust. I will be also getting B&B shorty headers and hyper tect 3 for the 3.42's. but thats about it for the mods... I want to be fast off line so that no rice burner can beat me.but want to have a good cruser as well. can anyone give some input as to what would be best..thanks jerryk :cry :cry
Old Jan 24, 2002 | 08:26 PM
Mitch C's Avatar
Mitch C
Default Re: Help!!!!!!! 3.42 (Jerryk)
JerryK, The 3.42s will make a dramatic difference in the performance of your car and a Torque Converter will make it even faster. If you are never going to race your car at the track you might want to stick with the stock converter. The stock converter stalls at 1600 according to the Yank Web site, but I have heard others say it stalls at 1800. My A4 appears to stall around 1600. If you decide to go with a converter try and drive a car with the converter you are considering. A converter can feel very loose to one person but might feel just fine to someone else it is a very subjective thing.
98 Purple Metalic
Powerloaded
3.15 Axle
Donaldson Blackwing
172 t.stat
In the garage 3.42s
[Modified by Mitch C, 6:36 PM 1/24/2002]
Old Jan 24, 2002 | 08:55 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Help!!!!!!! 3.42 (Buckmaster)
When I upgraded to the 3.42, I kept the stock TC. Not only did I think +$700 was a bit steep for an aftermarket TC, but I also didn't want to worry about traction problems when launching. I wanted a no-brainer technique when launching from a dead stop.
I believe TC selection should be made by the individuals driving style; its more of personal choice than a definitive yes/no decision.
[Modified by Mike Mercury, 7:59 PM 1/24/2002]
Old Jan 24, 2002 | 10:39 PM
curtowens's Avatar
curtowens
What exactly does the TransGo shift kit do for the car and what is the cost? Will the car still be a smooth cruiser until you hammer it? Does it cut the tires loose on the 1-2 shift? :confused:
Old Jan 24, 2002 | 10:50 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If you want a mild converter that you will not realize you have it, go Pro Torque 2400, very quick off the line! I might move up one day to a Yank 3500, but it must have an STR of 2.3.
Old Jan 25, 2002 | 08:26 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: Help!!!!!!! 3.42 (wallstAL)
:eek: :eek: :eek: :eek: :eek: Al is seeing the light, he may be Yanked!!!!!!!! :eek: :eek: :eek: :eek: :eek: :jester :blueangel:
Old Jan 25, 2002 | 08:27 AM
2000^C5's Avatar
2000^C5
The TransGo Shiftkit will drastically impove your tranny management with respect to shifting, firmness, and throttle response. You can drive the car normal without any bad affects, but when you want to go nuts or WOT the car will respond with crisp, firm shifts and yes you can spin as the car shifts :cheers: It is a kit and it is pretty cheap, about $80 but the install may cost you about $100-200, not bad for the gains and kick **** performance. Probably one of the best, inexpensive mods you can do for an A4. Especially if you get a higher stalling TC, because this TC will "loosen" your tranny up and the TransGo firms everything back up.
Sounds great, Vince is giving me a ride in his car this weekend, I will see if I need this kit! :D
Old Jan 25, 2002 | 01:40 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If you want a mild converter that you will not realize you have it, go Pro Torque 2400, very quick off the line! I might move up one day to a Yank 3500, but it must have an STR of 2.3.Al you would want the Yank Super Thruster 3500, standard str of 2.5 but they can reduce it to 2.3 for you :D
Thanks, that could be a plan, so long as I don't have any dead pedal.
Old Jan 25, 2002 | 03:20 PM
Jerryk's Avatar
Jerryk
Thanks everyone for the input, I think I might go for the Pro-torque 2400 this should be better than stock, I think I can feel the stock TC in forth gear you can kind of feel like you have a 5th gear almost like it shifts again is this the TC kicking in or something else?? :crazy: :crazy:
Old Jan 25, 2002 | 03:21 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
If I had to do 1 of the two, it would be the TC not the gears.
Old Jan 25, 2002 | 04:08 PM
2000^C5's Avatar
2000^C5
It will definitely be "looser"........TransGo Shiftkit will definitely fix that and will virtually eliminate any "looseness" :cheers: Mine goes in about a month from now....with the SY3500 and 3.42's :D
Are you going with the SY 3500 or ST 3500? I thought you were going for the ST 3500?
Old Jan 25, 2002 | 04:09 PM
2000^C5's Avatar
2000^C5
Default Re: Help!!!!!!! 3.42 (REDGAR)
Me too, and I would go without more than a PT 2400, go for a 3000 at least man, trust me, it won't be too much!!!!
Old Jan 25, 2002 | 04:33 PM
TCC5's Avatar
TCC5
Did Hypertech ever fix the problem with their unit for recalibrating gear upgrades? When Steve Cole had his motorcycle accident and I was waiting for my recal PL for upgrade gears....I decided to buy a Hypertech for the interim. Well guess what....the Hypertech didn't shift (A4)during WOT and would hit the rev limiter. Spoke to Hypertech and they admitted there was a problem with using their Programer for gear upgrades and they were working on it. You might want to check with Hypertech before you buy the HPPIII. :cheers:
:yesnod:(CLICK LOGO ABOVE) :yesnod:
'98 C5 A4 Torch Red Coupe
MODS: 3.42 Gears, Pro Torque Converter, TPIS LT Headers, TTS Power Loader II, Vortex Ram Air, WCC Power Duct, B&B PRTs Exhaust with Speedway Tips, Ported/Polished MAF,B&M Transcooler,Adjustable Fuel Pressure Regulator,Optima Yellow Top Battery, Redline Tranny and Gear Oil, PIAA 1100 Foggies, 172 Degree Thermostat, Painted Calipers (Folia-Tech),X-Pipe, TB Bypass, Lowering Kit, Chrome Wheels, LS6 Engine Covers, MOMO Cobra Shift ****, Z06 Screens,Lloyds Thick Pile Mats, Torch Red Interior Inserts, Exhaust Plate, Tinted Windows, Hyperwhite Headlights, BF Goodrich G-Force KD SSS, Z51 Swaybars, European Clear Tailights,European Side and Rear Amber Sidemarker, Wetokles,Z06 Rear Brake Ducts, White Gauges, Column Bypass, Framesaver Rollers, Chrome Seat Back Hoops, Top Down Window Commander, LAPD LED Third Brake Light
Waiting for Install: Stage II Heads/Cam, Yank 3500 Stall Converter (Upgrade), LS6 Intake Manifold, ASP Pulleys, MAF Translator, Mallett Repro Wheels, Specter Werks Rear Fascia
Future Mod(s): Pirelli PZero Rosso or GForce KD (Undecided),FLP Tranny? NOS? ATI SC? :confused:
[Modified by TCC5, 2:34 PM 1/25/2002]
To Help!!!!!!! 3.42
