MAF sensor, Stock or Aftermarket?
Old Feb 18, 2009 | 02:24 PM
C5Sweden's Avatar
C5Sweden
Default MAF sensor, Stock or Aftermarket?
Hello
Have a quite heavily modified LS7 based engine, N/A, in my 1999 C5 and making some additional power by nitrous.
So far I have been running with stock LS1 MAF sensor.
Question is, any gains in changing to an aftermarket MAF sensor, Granatelli for instance?
Thanx
Tommy
Old Feb 18, 2009 | 02:53 PM
KCvetteowner's Avatar
KCvetteowner
It would probably cost you the same to either:
1) buy a bigger MAF and have to get it tuned
2) delete the MAF and have your car tuned to run speed density.
Old Feb 18, 2009 | 07:59 PM
99 vett babycar's Avatar
99 vett babycar
there's no advantage to any after market MAF if you're using a stock TB. If you have a 90mm TB the go with a 2003 Z06 MAF
Old Feb 18, 2009 | 08:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
There are some 100mm MAFs now on the market which may be of substantial benefit to your big cube engine.
The Granatelli sure isn't one of them.
Old Feb 18, 2009 | 08:57 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Originally Posted by C5Sweden
Hello
Thanx
Tommy
Neither, ditch 'em all and go SD.
Old Feb 18, 2009 | 09:07 PM
breecher_7's Avatar
breecher_7
Pmass sells custom calibrated MAF's but id go SD......
Old Feb 18, 2009 | 09:24 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
SD works best in stable climates without wild temperature/humidity swings.
Breecher, you live in WI too, where we enjoy anything but that stability.
That's the one and only reason MAFs are still useful, they are a great compensator for weather.
Old Feb 18, 2009 | 09:35 PM
golfinz's Avatar
golfinz
If tuned right, SD can be just as stable...but the weather swings in WI are pretty wicked from what I see on the tube
Old Feb 18, 2009 | 10:05 PM
C5XTASY's Avatar
C5XTASY
Granatelli =
Ed
Old Feb 18, 2009 | 10:20 PM
KCvetteowner
The ZR1 did away with the MAF right??
Old Feb 18, 2009 | 11:25 PM
3XLSX's Avatar
3XLSX
Ditch the MAF and go speed density...
Old Feb 19, 2009 | 03:59 AM
C5Sweden's Avatar
C5Sweden
Interesting inputs guys, thanx.
For reference I am running 90mm LS2 throttlebody and a FAST 90mm intake aggressive cam and ported cyl heads etc.
Will look into the Speed Density way but over here in Sweden the climate changes can vary quite a bit.
Old Feb 19, 2009 | 04:09 AM
Justin-Sane's Avatar
Justin-Sane
leave it stock. changing the MAF will only work for a short time. the computer will eventually correct itself for the new MAF and run the same way it was before.
Old Feb 19, 2009 | 06:24 AM
breecher_7's Avatar
breecher_7
Ive been thinking that engine avatar picture looked familiar....
Very true, but sometimes SD is the only way to go once you reach a certain point. I know thats the point were at with the Blue Z06. This winter it got a new mill and a SD conversion.
Old Feb 19, 2009 | 06:52 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Speed Density is my thoughts too for your set-up, especially since you are FI with the NOS!
I would not go to a Granetelli -
Thanks,Matt
Old Feb 19, 2009 | 04:31 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Solid advice for a stock-sih 346 engine. But not applicable to this discussion.
When you step up into the 427-447 CI engine arena, like what's being discussed here (OP did say LS7-based), and assuming a minimum of a 90mm TB (95 and 102 TBs being widely used out there too), the stock 75 or 85 mm MAF quickly becomes a considerable restriction in the intake tract.
Something like this , or this can be quite beneficial in allowing the big cube engine to get the air it needs, while still measuring the incoming airflow...if your desire is to keep a MAF sensor at all.
Old Feb 20, 2009 | 03:41 AM
C5Sweden's Avatar
C5Sweden
Thanx, great input as always on this forum, I will let you guys know it works out when start tuning the new setup.
Did 10.41 on the quarter mile with the old setup so now I am looking in to going down towards 9.50 times this season...
Old Feb 20, 2009 | 10:28 AM
LDB C5's Avatar
LDB C5
Good info here So what would you guys recommend for my set-up (mods in sig below). I am going to be adding the Vararam air-bridge and relocating the MAF closer to hte ported 90mm TB.
Any suggestions? Will it require a retune?
To MAF sensor, Stock or Aftermarket?
