Power loss with auto vs 6spd
A4 you can multiply RWHP by 20% then add it to the total RWHP and that will give you your Crank HP
OR
A4 you can Divide RWHP by .82 and the total will give you your Crank HP.
Folowing the same formula above for a M6:
You multiply 15 %
OR
You divide RWHP by .86 and that will give you the total.
Remember that one you divide and the other you multiply and then add it to the total of the RWHP!
Thanks,Matt
RWHP = Engine HP X (1 - guess % of loss)
AND
for Engine HP KNOWING Rear Wheel HP and GUESSING the % of loss
thru the drive train :
Engine Horse Power = Rear Wheel HP divided by ( 1-guess % of loss)
So, for an M6 using the guess loss (12%) figure from the 2nd post:
RWHP = Engine HP X (1-guess% loss) =Engine HP X (1-.12)
= Engine HP X.88 = .88 Engine HP ;
Engine HP = RWHP divided by (1 - guess % of loss)
= RWHP divided by ( 1-.18 ) = RWHP divided by .88
Again, using the guess loss (18%) figure in the 2nd post for an A4 :
RWHP = Engine HP X ((1-guess % loss) = engine hp X (1-.18)
= Engine HP X .82 = .82 engine hp ;
Engine HP = RWHP divided by (1-guess % loss)
= RWHP divided by (1-.18) = RWHP divided by .82
These are "engraved in stone" mathamatical relationships. The Formuli DO NOT change from one car to the next BUT its the
"GUESS % of loss" that varies from one person to the next.
So, even though the Formuli are correct, different people will make different % of loss guesses and, thereby, will get different HP figures.
In fact, Tony Mamo , and many others,do not believe in the
"fixed ( throughout the entire RPM and rear loading spectrum) % of loss".
Regardless of your school of thought, since we're guessing at the percentage of loss thru the drive train, the BEST these Formuli will give youi is a good(?) aproximation of Horsepower.
1. Remove your engine from your car and dyno it.
2. Reinstall your engine and run it on a chassis dyno.
Then compare the difference and you will know your loss on paper.
But then take comfort in knowing you will be faster in 1/4 mile with the auto over a 6 spd in the same car.
I do not think there really is anything to do to a A4 that would reduce the amount of power loss. A higher stall will just help rpm levels on launch, it will do nothing for power loss.
You can reprogram the computer to shift a little better and to adjust the torque reduction done when shifting. However, it won't add to the power when in gear.
If you drag race, the A4 is best. But, if you don't then you could swap to a 6 speed. Its a LOT of work and is most likely not worth the 15 to 30hp that may be gained. But other factors could make it attractive.
What do you do with the Vette? 1/4 mile, street or ? Is there something besides dyno numbers that bother you?
Cheers
But as others have said it really depends how, where and what you want to do with your car that dictates a six speed vs an automatic.
Most people think it only comes into play on the launch but it isn't so it's also there with every gear change and even more so when using a higher stall/torque ratio converter!
If you ever notice when doing a back to back dyno on just the install of a converter the torque will always come up while the Hp decreases but the car will be quicker.
Usually in the .5 sec. range.
