Drag Radial Question
Old Jan 24, 2002 | 10:00 PM
stuart3232's Avatar
stuart3232
Default Drag Radial Question
first of all, will a 315 tire fit on a 9" rim? also can't decide on the nitto's or the bfg's?? not really worried about tread life, all i want is TRACTION!
Old Jan 24, 2002 | 10:25 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Drag Radial Question (stuart3232)
They will fit but the sidewall will be buckled.. I would rather see them on an 11" rim.. The BFG's hook better then the Nitto's but the Nitto's last a little longer and are better in the wet weather for the drive to the track..Pro's and con's of both..Good luck :seeya
Old Jan 24, 2002 | 10:49 PM
stuart3232's Avatar
stuart3232
Default Re: Drag Radial Question (CHRIS NJ C5)
thanks for the info chris!
Old Jan 24, 2002 | 11:06 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Don't hurt self, Tire Rack recommends 10 - 12 in rim.
17X11
315X35X17
Old Jan 24, 2002 | 11:17 PM
Ranger's Avatar
Ranger
I went with the BFG in 315.35.17 mounted on 12" wide wheels. With the rear brake cables tied down, fit is fine. The BFGs seem easier to properly heat, a plus if you don't have/want a line-lock. I have only four runs on mine after figuring out the heating process (1.82, 1.82, 1.79, 1.70). They also stay hooked to the shifts.
The BFGs are normally in shot supply; so if you go that way, buy them during the winter.
Ranger
To Drag Radial Question
