A4 Shifter Bulb Replacement (Pics)
I soon found out that you can lift the boot assembly off the shifter assembly and get to the bulb without taking out the whole shifter assembly first. Whole job from start to finish took a little less than an hour.
1. Remove the console and front radio/HVAC bezel as described elsewhere on the forum - do a search. Four nuts, three screws and disconnecting a few wires.
2. Remove the shifter **** for a little more room. There is a small U spring clip in the front at the bottom of the **** that just slips out using a flat head screw driver.
3. I peeled back the boot from the frame ring to see what was going on underneath - but its not really necessary. You can see the bulb socket when you lift the boot but it would be hard to get out at this point. Disconnect the plug for the wiring to the shifter at the front.
4. There are three plastic clips each at 12 (front), 3 (passenger side) and 6 (back) o'clock that hold the boot assembly ring into the shifter assembly frame. Gently squeeze the prongs together with a needle nose pliers starting in the back, then the side and lastly the front and the boot assembly will lift right out. I don't know if the order really matters. There is no clip on the indicator (driver's) side.
5. Flip the boot over and there's the lamp socket. Twist and pull it out.
That little bulb gets hot!
6. Replace the bulb and reassemble.
Definitely not a $250 project!
