LS6 Valve Spring Question
Old Feb 22, 2009 | 02:45 PM
geezel's Avatar
geezel
Default LS6 Valve Spring Question
Picked up a set of LS6 243 heads form a GM crate engine for an 04 Z06. Valve springs are bronze color with a yellow stripe. Are these the upgraded LS6 springs that are normally all yellow? I'll just be running a stock 02-04 LS6 cam.
Old Feb 22, 2009 | 03:48 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Interesting... I just picked up a set of 243 heads off an LS6 crate engine as well but mine have the yellow springs....hmmm
Old Feb 22, 2009 | 05:19 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Without seeing a picture ,I'd say that they are the stock springs.
243 Z06 heads come with the yellow springs .
Manny@E.C.P
Old Feb 23, 2009 | 08:54 AM
David426's Avatar
David426
Do a search in the z06 section.. There has been controversy over the stock springs breaking.. Many have the springs replaced for worry sake.. My 02 z06 is just fine and I will just leave it as it is.. The odds of one breaking are very low, but it does happen. I don't know if GM has addressed the problem or not. Probably not.. I thought i would at least post this so you guys know before you start the tear down.. You may reconsider,different springs as they are cheap.. Do a search at least before you move on
Old Feb 23, 2009 | 02:48 PM
geezel's Avatar
geezel
So does anyone know what bronze colored springs with mustard colored stripes are?
To LS6 Valve Spring Question
