TPMS Programing ?
Old Feb 22, 2009 | 06:27 PM
rkink's Avatar
rkink
Default TPMS Programing ?
I have a 1997. I'm getting the TPMS Failure warning on the DIC and the left front tire is not displaying a pressure. I recently purchased the car, so I have no idea how old the sensors are. I ran the fault codes in the DIC and only got one current fault, the C2100 Left front sensor fault. I went into the TPMS training function and was able to get a horn prompt from all 4 sensors. The left front still does not display a pressure. I assume this verifies that the battery is bad in the left front sensor, but my question is why I received a horn prompt on that sensor?
Old Feb 22, 2009 | 06:45 PM
Corvette Don's Avatar
Corvette Don
You said it, if you programmed them and are not getting a reading after driving (which you need to do after programming them if you didnt know) then the battery is dead or weak and is not strong enough to transmit a signal. If you need a rebuilt set with new batteries let me know. Gen I sensors are only supposed to last ~7 years so you are way above that.
Old Feb 25, 2009 | 10:59 PM
AWSUMC5's Avatar
AWSUMC5
Default TPMS Programming
I have a similar problem. Left front not showing any pressure, but after it got hot it would show L-XXX. I installed new battery in my left front TPS and now it will not program. Now both left and right front TPS show L-XXX R-XXX. Any suggestions? Do I need a new sensor. Checked now battery after installation and it showed 3.35v. Thanks for your help.
Old Feb 26, 2009 | 12:46 AM
fireman591's Avatar
fireman591
http://forums.corvetteforum.com/c5-g...batteries.html
Old Feb 26, 2009 | 11:27 AM
Corvette Don
You could have messed the circuit board up, its VERY easy to ruin them if you are not careful. I would stick to the guys who have done a ton of them for over 2 years now. http://forums.corvetteforum.com/c5-t...post1569093177
To TPMS Programing ?
