Why do you want to do that? Really shouldn't make much difference but could eventually wear out (or prematurely wear) the shift mechanism.
I guess it would help with heat if you are in major traffic for a long time in the summer time.
I would be afraid I would forget while I was distacted messing with the radio and then rev up to 4000 rpm before I realize what I did. Then all of the surrounding cars would think I didnt know how to drive the vette and they give me funny looks. Then I would return the funny look and then they would flip me off.
Looks like potental road rag to me. LOL
I put my manual shifting cars (Jeep and BMW) in neutral at long stop light - my leg gets tired in heavy traffic with many light. And sometimes I forget but only rev to 2k and then pop it in and go like a BO-OH (Bat Out Of H@ll).
One disadvantage of this would be the higher RPM's in neutral versus in drive. Seems like it would be slightly more wear on the engine and transmission from all this unecessary gear changes.
Another disadvantage would be the lack of control in an emergency situation. If you need to move quickly because of an emergency situation (someone coming up behind you and won't have enough distance to stop, etc.) you have an added step of shifting back into gear.
Actually the PCM compensates for this almost instanteously. Gone are the days of the idle stop solenoids. Same for the A/C compressor kicking in and out. Pretty much seamless in terms of engine idle speeds.
A tranny mechanic I know said the ONLY times you should shift to neutral are when you are going to sit for several minutes, or when your engine is obviously overheating. Reason: every time you shift from neutral to drive you engage and slip the 1st gear clutch plates. Doesn't seem like a very harsh abuse, but he pointed out that the other gear shifts disengage and engage the various clutches in harmony, to reduce the slippage, the fluid pressure is higher to reduce slippage, and the engine torque is electronically reduced to reduce force. He was telling me this while explaining how to replace the 1st/reverse plates on my other car, which he blamed on cold shifts to reverse in the garage, when the idle speed was still up a bit. So, I couldn't argue the logic. If you think about it, the N-1st shift bumps a lot more than a normal at-speed shift from, say, 3-4. Maybe he's right?
On a related question how about reving the motor while in nuetral on a A4. Have done this on occasion but not as a habit. Try to stay at 4k or below. Isn't this called dry reving?
Do a 4k neutral drop and say bye bye to your Torque Converter. A neutral drop will destroy them, maybe not the 1st time but it will.
No haven't had the urge to do it in any other car and it was only a few times. Like after having the exhaust installed and a couple of weekends ago in a parade with the club when everyone was doing it. I would never do a nuetral/drive drop. Just wondered about the free revs when not in gear.
Originally Posted by lucky131969
While in neutral, release the brake pedal....this will extend the life of the stop lamps too
Man...this forum is great
Nahhh, that's just small stuff. Shut off the engine at stoplights. Save LOTS of gas. Heck, the savings in gas alone far exceeds the replacement cost for the new starter you'll need every year.
I use to leave my car in gear while at a stop but not any more. When at a stop, I always put it in meutral to let the torque off the tranny. If I had a stall converter, I would probable leave it on gear. I can leave it now but have to hold the brake a bit harder. WHen in neutral, idle backs down to app. 800 rpm with a bit of shake.
I heard the same thing from a trusted transmission specialist.
Unnecessary shifting from neutral to drive, will cause needless wear on the transmission clutch packs.
