Wondering how to ID my MAF and Throttle Body. The guy I got the car from had a lot of work done and I would like to know if the MAF and Throttle body are stock or what. The car is a 2000.
The MAF has a number on the side which is 89873152607
The Throttle body has some numbers stamped on the front which are:
25317951 - 2A65242
0260 A2 - 021012A
Perhaps someone knows what these numbers mean or a place where I could find out. Maybe I should just check with a GM dealer but I really hate those guys.
Munch, I don't have my 2000 at the house, but I can check in a couple days and see what my numbers are. One quick way to check the MAF is to count the wires going to it; if it has 3 wires rather than 5, it is the stock 75mm 2000 type. If it still has the honeycomb air straightener in the front, then it's definitely stock, cause that's the first thing everyone removes when they decide to mod the MAF.
If the TB has a sharp, concentric ridge about an inch forward of the throttle plate (that the modders always machine down smooth) then it's likely stock.
25317951 - 2A65242
0260 A2 - 021012A
There is one listed in the C5 Section of that auction site ,It says CorvetteConcepts Performance Throttle Body and is stamped with one of the numbers you list 2A65242 .I have tried to google for more info but haven't come up with anything yet..Hope this helps ya
