A4 tranny removed
Old Feb 24, 2009 | 01:09 AM
matthew4201's Avatar
matthew4201
Default A4 tranny removed
Figured I would post up a few pictures of the tranny removal. Went much easier than I expected. Got everything loose up to the tranny in one afternoon then dropped it tonight. Next step is a run to the car wash.
These two web sites helped a bunch.
http://redshift.homestead.com/Drivetrain1.html
http://www.cajundude.com/differential.htm
Old Feb 24, 2009 | 10:34 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I've done this job a few times. It will be easier if you leave the torque tube in the car or if it also has to come out, pull them out bolted together and then reinstall seperately.
Old Feb 24, 2009 | 11:16 AM
matthew4201
I can definately see it being easier by leaving the torque tube alone. Ill have to do it that way going back in. Thanks for the tip.
Old Feb 25, 2009 | 12:56 AM
4DRUSH's Avatar
4DRUSH
So why did you remove it? Leaky rear?
Old Feb 25, 2009 | 10:26 AM
matthew4201
Second gear went out a while back. Going to freshen it up with new clutches, bands, and a shift kit. I also decided to go with a 3200 Vig stall since I had it out. Id like to do some 3.73 rear gears but I will probably wait on that right now.
Old Feb 25, 2009 | 04:57 PM
4DRUSH's Avatar
4DRUSH
Don't forget to put the catback in place before you raise the carriage.
Old Feb 25, 2009 | 05:17 PM
Bull_in_a_china_shop's Avatar
FWIW getting a pair of harbor freight tranny scissor jacks were VERY helpful to help articulate the drivetrain when it goes in. $150 well spent!! Balancing that stuff on floor jacks is for amateurs ;-)
Hope it all goes smooth!
Old Feb 25, 2009 | 06:55 PM
matthew4201
It was interesting keeping it balanced right. I put a ratchet strap around the tranny and through the jack which is probably the only reason we got it to work with a regular floor jack lol. I might see if any of my buddies have a tranny jack for going back in with it.
To A4 tranny removed
