We are offering this C5 radiator with Engine Oil Cooler and a custom hose package with internal bypass for only $775
Fits all C5 with manual transmission.
Any pictures with the hose kit installed? How much difference in flow/cooling over your kit with AN fittings and steel braided hose? I have one of your original adapter blocks with the bypass valve. It's been working great. I haven't reinstalled on my new engine yet. This one looks like a cleaner install.
Why does it need a bypass valve? Are you talking about a thermostat?
Actually it is a 7 psi bypass valve, built right into the adpater. What this does is limit the amount of pressure drop across the cooler and provide a constant flow at any rpm. We are working on a new pdf download on this that show the circuit and explains the concept in detail.
does the bypass take place of the an fittings..... would i still need the LPE block adapter? if you are supercharged which side do you want the eoc on? left or right? i see temps of 250 in traffic in the maryland summers. i have the stocker. thanks tom.
The assembly above is all you need. This is designed for left (driver) side only, which what GM did on C6 Corvettes. Many will argue about this being the hotter side of the radiator, which is true, but oil is much hotter than either side of the radiator and it works very well.
