I installed HID's in September. They turned on everytime as long as the car was on and running. If I tried to turn them on without the car running, they'd pop up, but only the driver's side would come on.
The other day I turned on the lights while the car was off. I realized it was off, so I turned them off and then started the car. I then turned them on and both lights turned on. Once I saw both were working I shut the lights off and turned off the car for the night. The following night and ever since, the passenger side isn't lighting up. I looked to see if all was plugged in tight and have even flashed the brights a few times. Any ideas??
Burned out bulb? Pull the connector from the bulb and see if there is power to the bulb. If so you could swap the drivers bulb to the passangers side and see if it lights up. If so you need to replace it
What HID setup do you have? Was it a conversion kit that replaces the entire housing or a simple bulb replacement? If it was a conversion kit; I would try swapping the relays between the two sides before doing anything else.
I bought them off fleabay. Guess I'll have to open up both sides again.
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Jason
On my HID's I have a fuse and relay for each headlight. That is how the plug in harness was setup. Just an idea if yours came with a new harness.
Jason
Hey Don! I'll have to check that out, I'm not sure. I forgot how it's set up. I'm going to check all that out tomorrow night. Are you headed to Lone pine this year?
Check your fuses, I have blown a couple with my HID's There is one for each light in the box under the hood.
Originally Posted by vetterdstr
Originally Posted by Blue 92
You really need to check the bulbs, ballast and fuses before spending $$.
Thank you all!!!! Unfortunately the other day i had ripped it all apart to check if all the connections were tightly plugged in. Now only to find out it was the fuse. I really really appreciated the advice!!!!
