I am in the process of replacing the reverse gear on my 99 6sp Vette. When I pulled the CV joint out of the diff I noticed that the diff output shaft is loose and instead of being centered on the opening it sags down about a half inch. I can easily wiggle it around in all directions. Passenger side is worse than drivers side.
The car drove fine (aside from the reverse issue). The fluid that drained out from the diff was grey in color. So what is the damage? Is it rebuildable?
Reason: added video link
I just bought a used diff on the forum here for Cheap$($250 shipped, believe it or not),No noises etc. and i couldn t have asked for more! (other than having a BEEFED up unit from RPM)! Depends on how much $$ you have to spend...
