OK, so I had my Vette on a trickle charger for the past 4 months and I decided that it was time to bring it out of hibernation. I tried to start it up and it wouldn't crank, so hook my jumper pack up and she came to life. I disconnected the jumper pack and let it idle for about 5 minutes while I dusted it off and checked the tire pressures.
I was noticing that the daytime running lights would flash on and off about every 5 seconds, so I shut it down and tried to restart it, but it wouldn't crank, so I jumped it again and it came to life once more. I disconnected the jumper pack and it idled for about 1 minute then it died completely and wouldn't crank.
My thought is that my battery is shot, but I thought that it was kinda weird that the engine would just die. The volt gage showed over 13 volts while it was running.
