Tire pressure sensor handling during tire changing
Old Jan 26, 2002 | 03:11 AM
mozin's Avatar
mozin
Default Tire pressure sensor handling during tire changing
I thought the 2001 C5 had the band around the wheel which held the tire pressure sensor but now I understand that the sensor is part of the valve stem.
Does the sensor/stem need to be removed and then reinstalled when mounting new tires, or is the sensor simply left in place on the wheel during the tire changeover?:confused:
Tom
Old Jan 26, 2002 | 07:53 AM
EHS's Avatar
EHS
Default Re: Tire pressure sensor handling during tire changing (mozin)
I don't know where this myth started (there was another post with the same misinformation recently).
It's not part of the valve stem, it's next to the valve stem on the wheel.
You might want to consider changing the small rubber donut on it (your local Chevy dealer wants about $5.00 for 4; AutoZone about .30 cents) when you change the tires, but that's about it.
:smash:
Old Jan 26, 2002 | 08:04 AM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Default Re: Tire pressure sensor handling during tire changing (EHS)
I'm not sure what you mean...sure looks like part of the valve stem to me!
Old Jan 26, 2002 | 08:18 AM
rwj383's Avatar
rwj383
Default Re: Tire pressure sensor handling during tire changing (Drop_Top_Dave)
DropTopDave, that is damming evidence!! yup, it IS part of the stem!!! HeeHEe!!
Old Jan 26, 2002 | 09:45 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Yes the sensor has to come off! The tire bead will damage it if it's not removed. Once the air is removed from the tire, just remove the nut on the valve stem and let the sensor fall down into the wheel.
Tom
Old Jan 26, 2002 | 10:04 AM
Tom Burgess's Avatar
Tom Burgess
Cruising
Yep, got to be removed before demounting. Check out this site for more details on tire changeout details:
http://www.hunter.com/pub/undercar/ppt/sldeshow.htm
Old Jan 26, 2002 | 03:11 PM
mozin's Avatar
mozin
Thanks for answering my question. I thought I would get one response with a simple yes or no but your responses were great. :yesnod:
Tom
Old Jan 26, 2002 | 03:56 PM
louzon's Avatar
louzon
Watched the guy change my tires the other day.
He didn't take the sensors off, but I did notice he was careful were it was positioned on the machine before he started stripping my old tires off. :)
Old Jan 26, 2002 | 04:02 PM
SILVER 97's Avatar
SILVER 97
Default Re: Tire pressure sensor handling during tire changing (louzon)
Same here. I just watched the guy change my tires. The sensors were not removed. My sensors still work fine. :cool:
Old Jan 26, 2002 | 05:41 PM
Steve Chaffee's Avatar
Steve Chaffee
6th Gear
Ok, check out this site: http://www.hunter.com/pub/undercar/PPT/sldeshow.htm
Hunter is a manufacturer of tire changing equipment and this appears to be their bulletin regarding handling of EMT tires and, to the point, pressure sensors.
I've also seen tires removed without removing the valve/sensor.
One final point: if you're in a snow area and drive the car in winter, you might want to tell your tire guy to be verrrry careful trying to remove the core (pressure release mechanism in the center of the valve) as it may be corroded. The corrosion doesn't seem to affect sensor performance, but if the core is damaged in removal, the entire sensor is shot. Sadly, I learned this the hard way. If the core is stuck, it's better to have the tire technician bleed the air out by hand.
Good luck.
Steve :cool:
ps: replace the rubber o rings AND lube them with silicone grease.
[Modified by Steve Chaffee, 9:44 PM 1/26/2002]
Old Jan 27, 2002 | 01:35 AM
EHS's Avatar
EHS
Default Re: Tire pressure sensor handling during tire changing (rwj383)
Drop Top Dave:
rwj383:
[b]
HeeHEe!!
Here's a picture of the sensor without the stem -- because it ISN'T a part of the stem:
And here's another picture of the sensor WITHOUT the valve stem, being installed in the wheel. Notice the valve stem is on the other side, being screwed into the sensor:
And here's a picture of the two separate parts screwed together:
So, if you go to the parts book, you know, the one produced by GM, you'll find that the valve stem and the sensor have two separate part numbers, because, let's see...,
oh my, they're separate parts, with two separate prices.
That's what I mean.
Pretty "damming evidence!! yup, ...!!! HeeHEe!!"
Hope this helps. :smash:
Old Jan 27, 2002 | 03:42 AM
mozin's Avatar
mozin
Nice pictures! :yesnod:
Tom
Old Jan 27, 2002 | 04:28 AM
EHS's Avatar
EHS
Thanks mozin, they're actually from the posts above with some commentary added for clarity.
The way I understood you're original post, I thought that you felt they were part of the valve stem, possibly inside the valve stem like the valve itself.
In fact, they're inside the tire, and the valve stem is screwed to them from the outside.
The "next to the valve stem" part comes in when it's time to reprogram them -- that's where you need to hold the magnet.
And remember, don't forget to change out the donut and lube it a bit as was posted by another member above.
Old Jan 27, 2002 | 05:36 AM
mozin's Avatar
mozin
I posted this question in the Wheel & Tire section but it got no response.
Has anyone tried to revive their tire pressure sensor after using the flat tire inflation gook? There must be some kind of solvent that could be used to disolve the gook out of the sensor. Any ideas?
Tom
Old Jan 30, 2002 | 04:57 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Tom-
From what I have heard, the solvent that makes the sensors work again is called "Money."
In other words, all posts I have seen say that the gook totally ruins them and you need to buy new ones. Hope I'm wrong.
Old Jan 30, 2002 | 08:09 PM
mozin's Avatar
mozin
Default Re: Tire pressure sensor handling during tire changing (Gearhead Jim)
Gearhead Jim,
I wonder if the gook just plugs things up or if actually bonds like a glue.
Tom
Old Jan 31, 2002 | 02:42 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I just bought two sensors for a 2001 and when I received them, the stems and sensors came as one, with one price, sealed in one GM bag :confused:
To Tire pressure sensor handling during tire changing
Old Feb 1, 2002 | 11:49 AM
Innocent Bystander's Avatar
Innocent Bystander
The myth must have carried over from the C4 Low Tire Pressure Warning System (LTPWS). The sensors were attached to the wheel with a band. They weren't monitoring sensors like the ones on C5... they just transmitted when the pressure dropped below a certain point. Then a light would come on the information center telling you to check tire pressure.
Old Feb 1, 2002 | 01:53 PM
jawski's Avatar
jawski
Default Re: Tire pressure sensor handling during tire changing (Innocent Bystander)
I had my wheels recently replaced...removed wheels from car...took wheels 5 miles away...did not remove the sensors before removing EMT tires...mechanic knew what he was doing.... marked the sensors for location RF,LF,RR ,LR...took them home waited a week for the new wheels...installed sensors.... didn't even have to recalibrate them.
Old Feb 1, 2002 | 07:38 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Tire pressure sensor handling during tire changing (jawski)
I just ordered a set of S03's from the TireRack and they said that the sensors don't have to be removed but you have to be very careful not to damage them.
