Oil pressure sensor module
Old Mar 3, 2009 | 03:38 PM
MindySu's Avatar
MindySu
Default Oil pressure sensor module
Hello.
Ihave a 98 Corvette Coupe. The oil gage or sensor module keeps shutting down. The oil gage pegs over all the way to the right. My DIC reads 130 psi which the service manager says is possibly a kinked line. I have had the sensor or module replaced three times. It only works correctly for a few months. The car does not burn oil and everything else works great. I am wondering is there a line from the sensor to the gage. If that is the case, I don't want to pay again for work that isn't being done correctly. Please help.
Mindy
Old Mar 3, 2009 | 05:06 PM
dougbfresh's Avatar
dougbfresh
Bad sensors, relocate it from behind the intake so it won't hurt so much when you have to replace it.
Old Mar 3, 2009 | 07:52 PM
Slick Rick's Avatar
Slick Rick
Originally Posted by MindySu
Hello.
Mindy
Hi Mindy, Its a bad sensor. Go to Kragen and purchase one. The ones they sell now are the brass bodied ones. More dependeble, or at least the one I installed has been. I went through 2 of the aluminum ones also One lasted about a month and the other lasted about 11 months. I live fairly close to you if you need help installing it. Its about an hour to 2 hour job. PM me and let me know.......
Old Mar 3, 2009 | 08:16 PM
LoneStarFRC's Avatar
LoneStarFRC
Hello.
Mindy
It is purely an electro-mechanical component. The only "line" that runs from this sending unit to the gauge inside the car is called "electrical wiring".
If you actually have a "service manager" tell you it is possibly a "kinked" line, feel free to tell him he does NOT know what he is talking about before you commence using a 2X4 liberally about his head or shoulders.
If you are having this work done at a GM dealership, they are pretty much required to stand by their work and replace it free of charge as it does have a warranty if installed by them.
Take some time to read the sticky at the top of this section on this matter.
Old Mar 3, 2009 | 09:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree totally! If it was done at a dealer, take it back. The part at least is warrantied by GM for a year. They do not warrant labor though. The alluminum ones don't appear to last unless you relocate them. As mentioned already, there are new brass ones coming out now which should solve most of these issues....hopefully.
Old Mar 3, 2009 | 10:33 PM
Slick Rick's Avatar
Slick Rick
As Mentioned above, If it was dealer installed and is a dealer part,buy all means take it back to the dealer its a freebie. If its been less than a year........
Old Mar 3, 2009 | 11:21 PM
jrprich's Avatar
jrprich
Lots of info here on the oil sender issue
http://forums.corvetteforum.com/c5-t...-relocate.html
To Oil pressure sensor module
