Engine is running very loud
Old Jan 26, 2002 | 10:56 AM
SonnyParker1's Avatar
SonnyParker1
7th Gear
Default Engine is running very loud
I've got a 97 coupe, and yesterday when I drove it, the engine sounded a lot louder than how it usually sounds during acceleration. The RPM's seemed OK since they were at around 2,000, but it was a lot louder than how it usually runs.
I haven't souped this car up, but right now it sure sounds like it. Anyone have any ideas on what this might be? Thanks.
Old Jan 26, 2002 | 01:00 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: Engine is running very loud (SonnyParker1)
...check for the obvious -
Loose Ex. pipe clamps, over the axle pipe not hitting the frame, loose anything - just take a look while its running and parked.
Old Jan 26, 2002 | 03:11 PM
MDT's Avatar
MDT
SonnyParker1,
Another thing you might consider in addition to those mentioned in the above posts:
There is the possibility that the baffles inside the mufflers are deteriorating, especially if the 97 has accumulated some high mileage.
I personally think you will find a loose or leaking connection, since the increased noise seems to have presented rather suddenly.
Good luck.
Mark
Old Jan 27, 2002 | 05:23 AM
molon labe's Avatar
molon labe
i came by last night and drilled holes in your exhaust. i didn 't think it was loud enough. ;)
Old Jan 27, 2002 | 07:46 AM
rwj383's Avatar
rwj383
Default Re: Engine is running very loud (tattooed)
then after he left, i removed the exhaust manifold gasket off the passenger side of motor!! (driver side too hard to get too in the dark!!) :p:
To Engine is running very loud
