LED problems....
Old Mar 6, 2009 | 12:07 PM
justin_heat05's Avatar
justin_heat05
Default LED problems....
I have chrome exhaust tips that have LED lights around them. Well I started off down the road this morning and noticed that 3 out of 6 were working. What could be the problem? The lights are on a circuit board.
Please not rude remarks. Only good advice.
Old Mar 6, 2009 | 01:09 PM
spdracr39's Avatar
spdracr39
bad ground or loose connection maybe.
Old Mar 6, 2009 | 01:31 PM
justin_heat05
does heat do anything to a circuit board LED? And if it does, can it be fixed? I don't know much about LED lights.............
Old Mar 6, 2009 | 03:21 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Heat will put an LED in it's grave fast....
Old Mar 6, 2009 | 10:45 PM
justin_heat05
thats what i thought, thanks.
Old Mar 6, 2009 | 10:52 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
There are some current disadvantages to LED lighting:
* LEDs are currently more expensive than more conventional lighting technologies, and may be hard to locate
* LED are very heat sensitive. Excessive heat or inappropriate applications dramatically reduce both light output and lifespan
Old Mar 6, 2009 | 10:55 PM
justin_heat05
Originally Posted by Blue 92
so why the heck do they make led exhaust tips..................
Old Mar 6, 2009 | 11:31 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Cause people will buy them.
Can you get the light apart so you can get to the backside where they soldered them to the board? If so I'd try hitting all the connections with a soldering iron. Worth a shot. My tail lights lost a strip of 4 and it was a bad joint. After I resoldered them they have worked flawlessly ever since.
To LED problems....
