Q-jet choice
Old Mar 6, 2009 | 01:37 PM
dalewilson99's Avatar
dalewilson99
Default Q-jet choice
What do you think about these carbs for an 81,350 slightly modified.
1. 17059284
2. 17058213
3. 7045212
The electronic carb and distributor had been removed before I got the car. A 17080213 was in its place. I am having trouble getting it to lean out.
Dale
Old Mar 6, 2009 | 01:45 PM
zeevette's Avatar
zeevette
Am I in a time warp?
Old Mar 6, 2009 | 01:46 PM
byronhunter's Avatar
byronhunter
Try posting in the "C3" section, lots of info.
Old Mar 6, 2009 | 02:15 PM
spdracr39's Avatar
spdracr39
Whats a "carb" ??
Old Mar 6, 2009 | 02:22 PM
blue63cpe's Avatar
blue63cpe
Originally Posted by spdracr39
Whats a "carb" ??
A paper cup with a hole in the bottom and the cup moves up or down for fast and slow.Man,I hate carbs!
Old Mar 6, 2009 | 03:03 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
1. 17059284
2. 17058213
3. 7045212
Dale
Are those Rochester, Carter, or Edelbrock part numbers? Also, what carb did the car come with? Usually a simple rebuild, with a jet/metering rod change to accomodate any modifications you made, is sufficient.
Old Mar 6, 2009 | 03:05 PM
timemender's Avatar
timemender
1. 17059284
2. 17058213
3. 7045212
Dale
Numbers 1 & 2 are from the late 1970’s era (78 –79)
Number 3 is from around 1975 – the start of the catalyst emissions era.
Post this in the C3 TECH section.
Is it too rich at full throttle, mid-range, or at idle only?
The Rochester Q-Jet is a very underrated carburetor. It can be touchy to dial-in, but once dialed-in it’s an ideal street carb.
You can find a wide variety of jets and metering rods available to accomplish proper fuel ratio.
You need to find a shop with an older engine mechanic with experience.
Parts and tech info can be found at the links below –
http://www.carburetion.com/quadrajet.asp
http://www.carburetor.ca/carbs/tech/...jet-index.html
Jim
Old Mar 6, 2009 | 04:33 PM
dalewilson99
Default my bad
Sorry I was in a real hurry when I posted this. I repost in the place I belong
To Q-jet choice
