I want to flush the old brake fluid out but don't know how much new fluid I need to do the job. Anyone help me out with how much I need to buy? A quart? 2 quarts?
I think the system capacity is 2 pints=1 qt. However, if you truly want to get ALL the bad fluid out, my experience is that you must do a four wheel bleed FOLLOWED by a long test drive in which you hit activate the ABS unit numerous times. Then, you have to bleed all four calipers some more.
So, if the fluid is 5-10 year old nasty fluid, I might get 2 qts even though if it's 1 year old fluid, all you need is 1qt.
