One HID light won't work
Old Mar 8, 2009 | 07:29 AM
DAV162's Avatar
DAV162
Default One HID light won't work
Installed HID's now the passenger ligth won't go on the first time. If I turn them off then turn them back on they both go on. Have installed the resistor so wonder if anyone knows what the problem may be.
Old Mar 8, 2009 | 10:21 AM
2000BC's Avatar
2000BC
Same here. Only happens once in a while. Off then back on, fixed. ?????
Old Mar 8, 2009 | 10:25 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Searched for a loose connection?
Old Mar 8, 2009 | 04:19 PM
DAV162's Avatar
DAV162
gone over whole system and no loose connections.
Old Mar 8, 2009 | 04:49 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Mine do the same, I just live with it.
Old Mar 8, 2009 | 06:28 PM
HWY HNTR's Avatar
HWY HNTR
Had this issue.. Fuse box near battery, look for fuse named something like LOW BM LT SIDE. Let me know if that works.
Old Mar 8, 2009 | 09:02 PM
DAV162's Avatar
DAV162
what do you do with the fuse I up graded the fuses to 20 amp.
Old Mar 9, 2009 | 05:56 AM
HWY HNTR's Avatar
HWY HNTR
Just replace it with a 10 as original. I replaced mine once in a year. Was it blown?
Old Mar 9, 2009 | 07:04 AM
DAV162's Avatar
DAV162
thanks will try it tonite
Old Mar 9, 2009 | 09:23 PM
spiral04's Avatar
spiral04
Old Mar 9, 2009 | 10:04 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Be careful when upgrading fuses. If the wire gauge is only rated for 10a, and the utlitizing device shorts a flow of current could be drawn greater than the wire rating, possibly exposing the wire to the 20a fuse limit. It could melt the wire, or cause a fire.
Old Mar 9, 2009 | 10:20 PM
HWY HNTR's Avatar
HWY HNTR
^ precisely.
Dav162: was it the fuse?
Old Mar 11, 2009 | 02:02 PM
DAV162's Avatar
DAV162
^ precisely.
No the fuses and the connections are all secure. Strange that once I have them on if I flash the lgths to high beam and then to low the light works. Any other suggestions.
Old Mar 11, 2009 | 02:50 PM
knyght4's Avatar
knyght4
Here's a crazy question. Is your motor running when you try turning on the light? This is an issue I have with mine if the motor isn't running.
Old Mar 11, 2009 | 05:39 PM
DAV162's Avatar
DAV162
It happens when I turn the car on and the lights come on automatically.
Old Mar 11, 2009 | 06:52 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
may be a bad ballast
Old Mar 11, 2009 | 07:12 PM
mickey_7106's Avatar
mickey_7106
relay?
To One HID light won't work
Old Mar 11, 2009 | 07:13 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
mine do the same thing...i think its a voltage issue?
Old Mar 11, 2009 | 08:10 PM
Tech's Avatar
Tech
I had the same problem. I ended up adding a relay and running dedicated power to the battery. First try swapping ballasts and bulbs side-to-side.
Old Mar 11, 2009 | 11:35 PM
Ryan L's Avatar
Ryan L
http://forums.corvetteforum.com/c5-g...d-flicker.html
