IAT Sensor relocation?
Old Mar 8, 2009 | 12:57 PM
jimbo1972's Avatar
jimbo1972
Default IAT Sensor relocation?
Hello,
I have a 98 Coupe w/ headers, exhaust, CAI, and a tune. Sitting in my garage from my old C4 is a Intake Air Temp Sensor relocation kit that will also work with a C5.
Anyone running one of these? If so, does it really make a difference? Where did you relocate the IAT to?
Thanks for the help
Jimbo
Old Mar 8, 2009 | 07:36 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
i moved mine to the front of the vararam intake. if you have HPtunes, you can set the cells not to be so sensative to heat soak, thus not removing so much timing when the tempture rises at knock. I think i explained that right
Old Mar 8, 2009 | 08:30 PM
Blow Torch's Avatar
Blow Torch
I moved mine to the upper portion of the filter housing in my vararam. That way it would get the cooler outside air instead of the heat off of the radiator.
While data logging my wife's car (with it in the stock location) the IAT temps would get above 100* at times
I just spliced in enough additional wire that it would reach.
Old Mar 8, 2009 | 11:53 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Is the IAT the sensor underneath the car in the radiator shroud area on the passenger side?
Old Mar 9, 2009 | 03:04 AM
c5mtl's Avatar
c5mtl
no its not...the sensor you are referring to is the sensor for the climate control....you iat sensor is either in the air bridge of built into you maf sensor...depends on your year
Old Mar 9, 2009 | 02:14 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Thanks. I always wondered what that sensor was for.
Old Mar 9, 2009 | 08:36 PM
PewtVette's Avatar
PewtVette
What is the climate control sensor used for?
Old Jun 5, 2009 | 01:44 AM
NemesisC5's Avatar
NemesisC5
Who sells an IAT sensor relocation kit?
Old Jun 5, 2009 | 10:10 AM
jimbo1972's Avatar
jimbo1972
I believe I got mine from Mid America or Ecklers.
Jimbo
Old Jun 6, 2009 | 12:05 AM
NemesisC5's Avatar
NemesisC5
Jimbo
Thanks Jimbo
Old Jun 6, 2009 | 12:14 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Yes, I put one on my 97. the rpms increased immediately...not sure why; but then it settled down after a few hundred miles...I think the computer self adjusted. got it from Ecklers...wait for the 10% off sale to save $5 if you are a thrifty shopper
Old Jun 6, 2009 | 12:37 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
With the VR Power Duct they moved the sensor right up near the maf and throttle body. Guess they don't care about heat.
Old Jun 7, 2009 | 04:02 PM
NemesisC5's Avatar
NemesisC5
Do you have Ecklers part number handy?
Old Jun 7, 2009 | 09:33 PM
$$$frumnuttin'
Nope, that was 3-4 years ago. just narrow your search to 97 corvette on the ecklers site and look in the engine or performance tabs.
Old Jun 7, 2009 | 09:51 PM
NemesisC5's Avatar
NemesisC5
Found it earlier....Thanks
To IAT Sensor relocation?
