Fuel Line Disconnect Tool?
Old Mar 8, 2009 | 07:00 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Default Fuel Line Disconnect Tool?
Is their something I am missing? I'm trying to take the fuel rails off a 2000 Corvette. I bought the disconnect tool and it doesn't seem to want to come off. I don't want to pull too hard and break it, any advice?
Thanks!
Old Mar 8, 2009 | 07:08 PM
00Corvette's Avatar
00Corvette
Just make sure it's the right size. Should be 3/8's inch I think...
Then just let the car sit for awhile to let the pressure bleed off and yes sometimes you do have to push the little tool "into" the fuel line pretty hard to get it to pop off...
Good luck!
DZ
Old Mar 8, 2009 | 07:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Insert the 3/8" disconnect tool over the rail stub tube, and while pushing the hose in (towards the rail), push the disconnect tool into the fitting outwards, towards the hose.
Once the tool is fully "in" the fitting and releases the internal clips, the hose should pull right off the rail.
Old Mar 8, 2009 | 09:41 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sometimes there is a little dirt in there that jams things up. Spray a little carb cleaner to get out any debris.
Old Mar 8, 2009 | 09:46 PM
NAVY08's Avatar
NAVY08
Thanks All, I'll give it another shot tomorrow.
Old Mar 9, 2009 | 09:33 PM
00Corvette's Avatar
00Corvette
Yeah...what those guys said too. LOL.
I forgot to mention that but it is a PITA if you don't push in on the hose too...
DZ
Old Mar 10, 2009 | 11:33 AM
Gordy M's Avatar
Gordy M
Also, you can use the two screw driver method. I had problems getting enough leverage using the tool and took 2 small/short screw drivers and pushed on either side and it cam off in a heart beat. That was after 1/2 of trying to use the tool.
Old Mar 10, 2009 | 12:11 PM
LoneStarFRC's Avatar
LoneStarFRC
Mine can be a little bit of a pain sometimes too. Sometimes repositioning the tool helps. Maybe one of the locking fingers gets into the slot or opening of the tool and doesn't get pressed in. I try rotating the tool slightly one way or the other.
Old Mar 10, 2009 | 12:22 PM
jedblanks's Avatar
jedblanks
I think someone kinda already said this, but you need to set the disconnect tool into place, then push the fuel line into the tool (towards the rail), then pull it off (holding the tool against it). The first action releases the clips, the second holds them apart to clear the "lip" that the clips hold onto.
The first time I tried it, I shoved the tool into the fuel line thinking it would disconnect and release. This intuitive motion does not work.
To Fuel Line Disconnect Tool?
