Confused....want your input
Old Mar 9, 2009 | 08:13 AM
4SFED Z's Avatar
4SFED Z
Default Confused....want your input
Ok. So I did a cam swap a month are so ago and have a few questions...
P0133 and P013 throws occasionally. Its slow response Bank 1 sensor 1 and Bank 2 sensor 1.
I looked for exhaust leaks and dont seem to have any. The 02 sensors are relatively new. I assume no problems there..will look once on lift.
Anyone else had this problem? I had a wide band hooked up and everything seems fine. When I start it in the morning and come to an idle, it seems to throw them both at the same time. Thats when the idle drops to about 100 or so and comes back up (cars warmed up to 130 ish) ... happens occassionally. When car is warmed up to about 200 its all good.
Old Mar 9, 2009 | 08:35 AM
KCvetteowner's Avatar
KCvetteowner
the easier things to check are your sensor wires around your headers. Then check your wiring harnesses, as your engine jiggles (more with a cam) it will rub against the wiring harness along the back edge of the block and eventually wear into the harness. Check your knock sensor wires aren't pinched at the rear of the block (use a mirror on a stick).
