Harmonic Balancer Question...
Old Mar 11, 2009 | 04:56 PM
Out To Lunch's Avatar
Out To Lunch
Default Harmonic Balancer Question...
Hi All,
I'm new to the site and have already been over to the intro part, and now I have the first of maybe many questions. I just bought a '99 FRC with high miles on the clock. (It was a well taken care of daily driver)
Anyway I started to hear a whine/chirp coming from the from the front of the engine and found the harmonic balancer has a wobble to it. I'm not comfortable with this so I'm going to change it.
My question is I've found, both SFI approved, a stock style replacement and another with a 25% under drive. This car is going to be a good weather cruzier for my wife and I. I'm would like to know what thoughts there are on which one to install considering our use for the car. I want a car to get into and drive from 5 to 500 mile at any time.
Foot Note: I like to tinker with performance and this is "My Hot Rod".
Thanks,
Don
Old Mar 11, 2009 | 05:18 PM
kerryt1's Avatar
kerryt1
I experienced a similar issue, and replaced mine with a Powerbond 25% underdrive unit. It is a nice piece, and I have yet to experience any cooling, charging, or other issues. I bought mine from forum vendor Byunspeed as a kit with new belts.
It's quite a job, requiring removal of the steering rack among other things but can be done in one's garage with patience. You will also need a new GM or aftermarket (ARP) crank bolt.
If you EVER plan on installing an aftermarket camshaft, this is the time to do it so you don't have to repeat work. Just a thought.
Old Mar 11, 2009 | 06:12 PM
2GOFAST's Avatar
2GOFAST
Old Mar 11, 2009 | 06:54 PM
Out To Lunch
Thanks for the feed-back... I think I'll be going with the under drive unit and not think about a cam change for now.
BTW, where would one get a set of ramps that would allow me to get such a low car high enough to roll under? I'm sure some of the work will be easier to get done from below???
Sorry for all the questions, but once I start this job I don't want to stop. We sort of live in a semi remote area and most uncommon (for our area) items take added UPS or Frgt. time.
Old Mar 11, 2009 | 07:22 PM
geezel's Avatar
geezel
Do a search on "Lifting the C5" or "Jacking the C5". There is a post about making your own ramps and supports out of common lumber. Works great for me.
Old Mar 11, 2009 | 08:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Ramps won't really help you, because you'll have to take the front wheels off in order to remove the steering links, as the entire steering rack must be removed to facilitate swapping the balancer.
Also, don't forget to order a new balancer bolt as well, it is a one-time use fastener.
Old Mar 11, 2009 | 11:33 PM
T.J.'s Avatar
T.J.
Forget the ramp and buy a kwiklift kit. I bought the standard lift and it paid for itself with one use.
Old Mar 12, 2009 | 11:43 AM
Out To Lunch
Thanks again, a lot of gooooood info here. I built a new shop in the last 18 months and have a used 2-post lift but have not installed yet. Guess it's time.
Don
Old Mar 12, 2009 | 02:08 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I drive my car up on 2x10s, which gets the front end high enough for me to weasel a low profile jack under the front crossmember.
Old Mar 12, 2009 | 02:57 PM
kerryt1's Avatar
kerryt1
This is what I did, here's an "in progress" shot:
Don
This is the way forward.
To Harmonic Balancer Question...
By Michael S. Palmer | 2026-06-03 11:00:24
