Hitting bump causing CE for O2 sensors?
By the time we got the car home, the CE light was on, and the codes were the 2 from O2 sensors before and after the cats,
After changing the battery to a 78 as opposed to 75, which didn't have the right amount of power, the CE light went off, and didn't come back for quite a long time.
We drove (slowly) over a somewhat rough railroad track, and the CE light came on immediately with the same O2 sensor codes again.
Is there a possibility that the first hit caused loose wires/ connectors/ etc, everyone we talk to wants to change out the entire cat system- which I am not convinced is the problem.
I do notice however, that when starting off in 1st gear there is an odd vibrating type sound in the exhaust near the cat area.
Any thoughts?
Thank you!
