Stock exhaust broken - be repaired?
Old Jan 27, 2002 | 07:13 PM
Terry McGregor's Avatar
Terry McGregor
Default Stock exhaust broken - be repaired?
Posted in general section (oops), but it should be here...
I started my '99 today and noticed it was much louder than normal. I went underneath to see what's what and I found that the pipe that goes from the muffler over the rear axle was no longer connected! The pipe is welded to a flat phlange that is bolted to the phlange on the rear of the straight pipe heading toward the engine. The weld between the rear pipe and the rear phlange just let go! Nice and clean. The two phlanges are still bolted together and the "weld" is attached the the separated pipe - no rust or corrosion - nothing. The phlange looks clean as if nothing had ever been welded to it in the first place.
The car has 16,500 miles on it and is almost 4 months out of 3/36 warranty. I have GMPP 72/75 zero deduct but the contract says exhaust is not covered. What do you think, should GM "good will" it. Can this pipe be re-welded to the phlange or do I need to replace from the phlange all the way back to the tail pipes (looks like one piece)?
Thanks...
Terry
Old Jan 27, 2002 | 09:34 PM
C5 Tweaker's Avatar
C5 Tweaker
Default Re: Stock exhaust broken - be repaired? (Terry McGregor)
I bet your dealer will phix it phor phree. Be sure they use stainless welding wire.
Old Jan 27, 2002 | 09:39 PM
aces's Avatar
aces
Default Re: Stock exhaust broken - be repaired? (C5 Tweaker)
As stated above....... Make sure the correct wire is used! :cheers:
Old Jan 27, 2002 | 09:52 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
This is a common problem that I see all the time.It is always a clean brake and can simply be rewelded.The factory welds are poopie...It happens on both the front H pipe,and the pipe going back to the mufflers,so have all 4 flanges checked...
Here is the part that will really **** you off :yesnod: Technicly,GM's policy is to not "goodwill" something if you have an extended warranty (GM doesnt want to pick-up the tab if an extended warranty wont cover it) :eek: That front pipe is in the $1,000 range and the GM replacement muffler is about $300 each :eek: At least try and get them to weld it,and good luck...Chances are you wont get someone who knows policy ;)
Old Jan 27, 2002 | 10:41 PM
Tiger Shark's Avatar
Tiger Shark
Just saw your post, Terry. If you decide to replace it with another stock exhaust, shoot me an e-mail. I'm selling my 2002 exhaust for $200 (+ shipping). http://forums.corvetteforum.com/zerothread?id=227590
Old Jan 27, 2002 | 10:59 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Try the dealer first and see if they will goodwill the fix. If not, any decent muffler shop will be able to reweld the pipe to the flange for you. Should cost in the $25-30 range to do it correctly. Need to tack weld the pipe first to insure proper fit. Be sure that they use stainless wire in the mig welder !!Then disconnect the flange so it can be welded properly around the entire pipe/flange connection. New gasket and re-bolt - good as new. The whole operation should not take more than 1/2 hour.
Old Jan 27, 2002 | 11:12 PM
BillY2KFRC's Avatar
BillY2KFRC
The exact same thing happened to my exhaust after drag racing my car. Clean break. Just had it re-welded. Had the other side re-done as well to make it stronger, the factory welds did not look very strong at all as C5-Tech said.
Old Jan 28, 2002 | 03:08 AM
EHS's Avatar
EHS
Just Midasize it.
Should be a 15 minute welding job at a good shop.
Old Jan 28, 2002 | 08:28 AM
geekracer's Avatar
geekracer
Another option would be to replace it with another stock part. You may be able to pick up a used part from someone who switched out. :smash:
Old Jan 28, 2002 | 09:44 AM
RyanC7's Avatar
RyanC7
Default Re: Stock exhaust broken - be repaired? (MMarquez)
Good Idea.......My stock mufflers just went up for sale.......just the mufflers since I had to cut the h-pipe to get the XR-1 on. Send me an email if you want them, Im moving soon anyway and would like to clean out the garage.. The mufflers have about 1500 miles on them. I will post this in for sale as well.
Old Jan 28, 2002 | 09:45 AM
vmspionage's Avatar
vmspionage
phunny.. :lol:
:seeya Jeff
Old Jan 28, 2002 | 09:58 AM
RWhite's Avatar
RWhite
Default Re: Stock exhaust broken - be repaired? (vmspionage)
To bad you don't live in Plano, Texas. Pronto Mufflers would probably fix it free, with just a tip the installer. If the dealer does not come through, than I bet any muffler shop that is not busy at the moment, would do it for almost nothing! They like to hoist up "Vettes and look under them! Don't we all!
To Stock exhaust broken - be repaired?
