Service Vehicle Soon
I've been getting the "Service Vehicle Soon" message for a good while now on my 98. When I had it in the shop for some other work they told me that the problem was with the Steering Position Sensor. I believe that could be the problem because I have had the steering column off before (don't remember why...when I replaced the rack maybe?) so my guess is that when I put it back together I got it close enough that it didn't report this error...until now.
Anyway, I'm looking for instructions on how to adjust or maybe removal and replacement procedures for the Steering Positon Sensor. Can anybody point me in the right direction?
Document ID# 1207387
1998 Chevrolet/Geo Corvette
Steering Wheel Position Sensor Centering
Removal Procedure
Important
Identify the type of steering wheel position sensor from the illustrations below BEFORE removing the sensor from the steering column. Once you have identified the steering wheel position sensor, follow the instructions listed in the removal procedure.
Verify the type of steering wheel position sensor.
From the technicians point of view, the FRONT of the sensor (1) connector will be on the right.
Important
If reusing the existing sensor, you do not have to align the sensor before removal. Centering is not required when it is time to reinstall.
Remove the connector from the sensor.
Remove the sensor (1) from the adapter and bearing assembly.
To install the sensor, proceed to step 1 in the installation section.
From the technicians point of view, the FRONT of the sensor will have:
foam ring (2)
pin hole (1) for centering pin (note location of pin hole)
flush rotor flange cuff (4)
Important
If reusing the existing sensor, you must make an alignment mark on the rotor flange cuff (3) before removing the sensor. Failure to do so will cause misalignment when installing the sensor. A new sensor will be required if misaligned.
Make an alignment mark on the flush rotor flange cuff (3).
Remove the sensor from the adapter and bearing assembly.
To install the sensor, proceed to step 5 in the installation section.
raised rotor flange cuff (3)
alignment mark (2) on rotor flange cuff (3) for installation
To install the sensor, proceed to step 9 in the installation section.
sensor clip in FRONT of the sensor
Remove the sensor clip from the sensor.
To install the sensor, proceed to step 13 in the installation section.
alignment mark (2) on flush rotor flange cuff (3) for installation
To install the sensor, proceed to step 17 in the installation section.
pin hole (2) for centering pin (note location of pin hole)
alignment mark (3) on flush rotor flange cuff (4) for installation
foam ring (1)
To install the sensor, proceed to step 21 in the installation section.
Installation Procedure
Important
If reusing the existing sensor, no centering of the sensor is required.
If installing a new sensor, it will come with a pin installed in the sensor. Do not remove the pin until the sensor is seated.
From the technicians point of view, the FRONT of the sensor (1) connector will be on your right. From the technicians point of view, the BACK of the sensor (2) connector will be on your left.
Looking at the FRONT of the sensor, align the sensor with the steering shaft and install into the adapter and bearing assembly.
Install the connector to the sensor.
foam ring (4)
pin hole (7) for centering pin (note location of pin hole)
flushed rotor flange cuff (6)
alignment mark (5) for installation
From the technicians point of view, the BACK of the sensor will have:
double D flats (1)
foam ring (3)
alignment tab (2) for installing into the adapter and bearing assembly.
view of the inside of the connector
Important
If reusing the existing sensor, you must align the marks on the flush rotor flange cuff before installation. The alignment mark must stay aligned until the sensor is seated into the adapter and bearing assembly.
If installing a new sensor, it will come with a pin installed in the sensor. Do not remove the pin until the sensor is seated. If the new sensor did not come with a pin installed, you must reorder a new sensor.
pin hole (3) for centering pin (note location of pin hole)
raised rotor flange cuff (5)
alignment mark (4) for installation
double D flats (1)
Important
If reusing the existing sensor, you must align the marks on the raised rotor flange cuff before installation. The alignment mark must stay aligned until the sensor is seated into the adapter and bearing assembly.
raised rotor flange cuff (4)
alignment mark (3) for installation
From the technicians point of view, the BACK of the sensor will have an alignment tab (1) for installation. This sensor does not have double D flats.
Important
Important
flush rotor flange cuff (5)
foam ring (6)
double D flats (1)
Important
Your problem may be fixed by just disconnecting the shaft from the rack and properly re-attaching it after turning it to the proper orientation. The car isn't a 60 Chevy.
Bill
