The procharger will work on your Z06. The system will make about 470-480rwhp with the supplied Superchips Programmer, if you have someone with superchips tuning ability and a dyno you can make more power as the programmer will be tuned to your car perfectly. We are an ATI dealer and Superchips dealer with an inhouse dyno so it works excellent that way. The kit is pretty straight forward in install. Don't however recommend installing unless you are very comfortable with your skills and knowledge of your car. We install them and have sold many to date. You can check them out on our website for more info. Or give us a call would be glad to answer any questions you might have.
If you would add a supercharger to a modified(non stock) engine without having access to a dyno, would it be possible to add high flow injectors and use the MAF translator to have the PCM to add more fuel and tune the setup without a programmer ?
An example are if you already have a modified engine with custom programming, you would not use a programmer as the one supplied with a ATI kit because it's made to be used on a stock engine, correct ??
Sure it will work... :yesnod: But that is not the important question for your Z06. The important question is "how long will my engine last" with the SC?
IMHO...not long. That's why many have not recommended using them on a stock Z06.
Good luck
The saga continues......I am also getting a kit installed soon on my 01...Nick at Agostino racing is doing it..He will be experimenting with it to get maximum boost, proper air/fuel ratios..A differend injector will be used, it is the first STOCK Z they will do..They are doing a blower on a 427 now :eek: I will report my experience on this, i want maximum power, and a large dose of common sense to go with it...Hoping for 500RWHP, but that may be a bit much..Gotta love it :D
