I am installing a pillar gauge pod with a fuel pressure gauge. Where can i run the wires for the gauge thru the firewall on the drivers side? The hole where the hood release cables come thru is not big enough for the plug for the gauge to come thru. Thanks
There is a spot on the passenger side. It the main wires comming out of the firewall. Just untape, and you can run the wires through the grommet, then retape.
