12v switched,constant
Old Mar 18, 2009 | 09:27 PM
bowtiebubba's Avatar
bowtiebubba
Default 12v switched,constant
Where are the 12v switched & 12v constant locations in the dash area?
Old Mar 18, 2009 | 09:50 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Look down in the passenger footwell. There is a black conector with those wires and a ground.
Old Mar 18, 2009 | 09:56 PM
ALLEGRO's Avatar
ALLEGRO
If you are talking about connection places then c5blkvetteguy has you covered.
If you are referring to "power points" or "outlets," then they are both constant. One in the console and the other in the ashtray area.
Old Mar 19, 2009 | 06:11 AM
bowtiebubba
I have 2 gauges,linelock,shiftlight, & nitrous switches to wire up. Some want 12v switched and some want 12v constant.
Old Mar 19, 2009 | 07:05 AM
trussme's Avatar
trussme
Default this is what you're looking for...
There is a HOT, GROUND and SWITCHED aux wire in the passengers foot well. It has 12 VDC HOT, 12 VDC Switched and GROUND. If they have never been accessed they’re going to be wrapped in black duct tape.Look in the foot well, remove the TOE BOARD, and you will see a big silver box (the BCM). The wires will be above the box to the left near the fire wall They will be orange, yellow and black. The wires are dead ended (not attached to any thing)
The YELLOW is ON when the key is in ACC or ON position and is served by Fuse 11 in the I/P fuse block,The ORANGE is ON at all times, and is powered off Fuse 7. The BLACK is GROUND and is grounded at G202
Old Mar 19, 2009 | 09:35 AM
bowtiebubba
This is probably going to be a really stupid question. When wiring something like a nitrous switch, it has a 12v switched wire,a ground wire,& a to accessory wire. What is the accessory wire & what does it do?
As you can probably tell i know nothing about wiring.
Old Mar 19, 2009 | 09:09 PM
bowtiebubba
ttt
Old Mar 20, 2009 | 12:27 AM
c5blkvetteguy
The switched wire is power to the switch, The acc wire is power from the switch to what you want to turn on, and ground is ground. Hope that helps.
To 12v switched,constant
