grass in grill
Old Mar 19, 2009 | 08:29 AM
gorghamak's Avatar
gorghamak
St. Jude Donor '10-'11-'12-'13-'14
Default grass in grill
hello to everyone on the forum i hope we all survied winter
i live down a grass drive my 99 is sucking grass into the radiator
really bad can i install a manual switch on the fans for this 500 ft drive
and if so where
thanks
gorghamak
Old Mar 19, 2009 | 09:12 AM
dancin1's Avatar
dancin1
Default Sucking grass.
Good morning, have you thought about a trash screen uinder the opening for the air intake area ? Very easy installation and works rather well.
Old Mar 19, 2009 | 01:07 PM
oh1vette's Avatar
oh1vette
Check out Elite Engineering for a radiator screen, I got one and its a solid piece.
Old Mar 20, 2009 | 02:17 AM
striper's Avatar
striper
The fan running would probably cause you to suck up more grass. I would do the screen over the opening. You can buy aluminum screen used in home construction at the Home Depot for about $7 for a piece about 2' x 8', enough to make a bunch for yourself and your friends. If you check out some of the vendors sites you can see how it installs. A couple of them even sell their kit for about $50 and it's made from the same $2 worth of screen. BTW, before the screen I once found a Mickey D's french fry container up in my radiator.
Old Mar 20, 2009 | 09:09 AM
AJay's Avatar
AJay
One problem -A screen will block airflow.
How about just killing the grass on your drive?
Old Mar 20, 2009 | 11:25 AM
bobby777's Avatar
bobby777
Get some good paper and let the grass dry--roll it and enjoy it
Old Mar 20, 2009 | 11:27 AM
itzza427's Avatar
itzza427
Kill the grass!!
Old Mar 21, 2009 | 02:53 AM
striper's Avatar
striper
The screen I was writing about is not a fine screen mesh like on a window, it is a larger type of diamond shaped holes that are used in plaster walls, I think. It has no negative affect on airflow whatsoever, my car still runs cool with it installed. If anything, it probably stays running cool longer because no trash can be sucked up into the radiator core.
To grass in grill
