What is suspension fluid?
Old Jan 28, 2002 | 03:04 PM
vettvert's Avatar
vettvert
Default What is suspension fluid?
After looking at all the different fluids made by Redline, I noticed this one which threw me for a loop. They have many grades of suspension fluid as well.
Old Jan 28, 2002 | 03:28 PM
MitchAlsup's Avatar
MitchAlsup
Default Re: What is suspension fluid? (vettvert)
In the motorcycle world, we often change the fluid in the shocks as a regular maintanence item. If you think the shock is too soft, you can use a stiffer fluid, conversely if you think the shock is too stiff, you can go to s thinner fluid. After the shock is in the ball-park, you can use the compression and rebound adjustments to fine tune your suspension. We mainly use synthetic fluids and change then at 12000 miles+/-. This stuff is like motor oil, but doesn't have the anti-wear package for engine-like loads, not the anit-wear package for trannies and differentials. I'm sure it has some package that optimizes this fluid from its oil-stock base into shock fluid, but don't know what it might be.
Old Jan 28, 2002 | 03:32 PM
vettvert's Avatar
vettvert
Default Re: What is suspension fluid? (MitchAlsup)
Thanks Mitch.
To What is suspension fluid?
